.NET
How to send the text command from vb.net 2005 to AutoCad 2008
6 REPLIES 6
1505 Views, 6 Replies
I`m v.new to programming vb.net 2005 with AutoCAD 2008.
I just saw a presentation about how to send commands through SendStringToExecute method.
My code is like that:
Imports System
Imports System.IO
Imports System.Collections.Generic
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports AcadApp = Autodesk.AutoCAD.ApplicationServices.Application
Public Class DGCommand
_
Public Sub Asdkcmd1()
Dim acDoc As Document = AcadApp.DocumentManager.MdiActiveDocument
acDoc.SendStringToExecute("._text '(10.0 10.0 0.0) 5 0 TestArcGIS", False, False, False)
acDoc.SendStringToExecute("(\n)", False, False, False)
End Sub
End Class
This script code ("._text '(10.0 10.0 0.0) 5 0 TestArcGIS", False, False, False) is not correct.
Can anyone help me with this easy task.
6 REPLIES 6
Can you cite the source of the presentation?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6350149@discussion.autodesk.com...
method.
Imports System
Imports System.IO
_
End Sub
End Class
False)
is not correct.
Hi Tony...
I didn`t get what you want me to do from your question "Can you cite the source of the presentation?".
I explained that it is my first step in using ObjectARX libraries through VB.Net code.
I count in your assistance in order to undertsand some issues regarding those libraries.
So, Can you show me a Vb.net example about the function SendStringToExecute.
Thank you.
There may be cases where using "SendStringToExecute()" makes sense, but
since you are "new to programming...", it is definitely not good way to try
out Acad .NET API. You should avoid the temptation of doing programming as
if you are just issuing Acad built-in commands (running script file *.scr
would be a lot easier for that). SendStringToExecute() is rather advanced
topic.
For your question of creating a text in drawing, there is .NET API
object/method to create text (DBText/MText).
"dawoodeg" wrote in message news:6350149@discussion.autodesk.com...
Imports System
Imports System.IO
_
End Sub
End Class
False)
is not correct.
Where did you get the sample code from?
wrote in message news:6350420@discussion.autodesk.com...
Hi Tony...
code.
libraries.
Thank you.
Greetings,
Mr. Norman... Please note that I have 2 years experience as a GIS Developer and I want to create a tool that add attributes like those of GIS features to CAD features and let the Cad user assign data to these attributes through an interface.
Mr. Tony...Upon your request, the source of the sample code. I got it from the DS09_TS_83_AutoCAD.wmv demo.
My question was to find the alternate code in vb.net of the following line of code:
acDoc.SendStringToExecute("command \"_text\" '(10.0 10.0 0.0) 200 0 \"Hello, World\")",false, false, false);
Thank you a lot guys...
A google search of that demo only turns up this post. Where did that demo come from?
”Boost
