.NET
How to select all groups whitch the groupname contains 'PART-*'
2 REPLIES 2
swaywood
605 Views, 2 Replies
Hi all:
in a drawing there are many groups.
the group name just like 'PART-1','PART-2','PART-…'
can i use a filter to select all the groups at ont time?
I am new, could you kindly give me some code to learn how to do that?
best regards
swaywood
2 REPLIES 2
_gile
in reply to: swaywood
You can't use a selection filter, but you can get the ObjectIdS of the entities within the groups which names match a specified pattern.
SelectByGroupName(db, "PART-*");
        private ObjectIdCollection SelectByGroupName(Database db, string pattern)
            ObjectIdCollection result = new ObjectIdCollection();
            using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
                DBDictionary NOD = (DBDictionary)tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
                DBDictionary groups = (DBDictionary)tr.GetObject(NOD.GetAt("ACAD_GROUP"), OpenMode.ForRead);
                foreach (DBDictionaryEntry entry in groups)
                    if (Utils.WcMatchEx(entry.Key, pattern, true))
                        Group group = (Group)tr.GetObject(entry.Value, OpenMode.ForRead);
                        foreach (ObjectId id in group.GetAllEntityIds())
                            result.Add(id);
                tr.Commit();
            return result;
Gilles Chanteau
GileCAD
GitHub
swaywood
hi,gile:
thank you so much!
I'll try it.
best regards.
swaywood
”Boost
