.NET
.NET
0 Kudos
Post 1 of 18
How to select a drawing object which is in AutoCAD File from a .Net Application?
2159 Views, 17 Replies
07-17-2012 06:42 AM
Hi All,
I am trying to create a small application in C#.Net where by clicking a button, I should be able to select a drawing object in the AutoCAD file to get the object's handle.
I am able to open the Drawing file from the application but unable to figure out how to get the drawing object handle by clicking on it through the application.
Can anyone help with a code example ?
Imports Autodesk
Imports Autodesk.AutoCAD.Interop
Public Class SelectOnScreen
Private Sub SelectOnScreen_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
SelectHandle()
End Sub
Sub SelectHandle()
Dim acadDoc As AutoCAD.Interop.AcadDocument = Nothing
Try
acadApp = GetObject(, "AutoCAD.Application.18")
Catch ex As Exception
End Try
If acadApp Is Nothing Then
MessageBox.Show("Unable to Connect to AutoCAD", "AutoCAD Message", _
MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
Exit Sub
End If
Dim sset As AcadSelectionSet
SsetMake(acadApp.ActiveDocument, "sset")
sset = acadApp.ActiveDocument.SelectionSets.Item("sset")
sset.SelectOnScreen()
For Each item As Object In sset
MsgBox(item.handle)
Next
End Sub
Public Sub SsetMake(ByVal thisDrawing As AutoCAD.Interop.AcadDocument, ByVal ssetname As String)
Dim ssetcheck As Boolean
For Each sset In thisDrawing.SelectionSets
If sset.Name = ssetname Then
ssetcheck = True
Exit For
End If
Next
If ssetcheck Then
thisDrawing.SelectionSets.Item(ssetname).Delete()
sset = thisDrawing.SelectionSets.Add(ssetname)
Else
End If
End Sub
End Class
I believe the error you got is compiling error, not runtime error. That is, your code does not compile.
1. The first compiling error:
Not like VB, in C#, you need to pass parameteres for the optional argument:
SelectOnScreen(Type.Missing, Type.Missing);
2. The second compiling error: that is because C# is strong type language, ab "object" natually does not have property that from an specific class instance. YOu need to cast the "object" into a correct specific type before to access the property. In your case, you need:
foreach (object item in sset)
    AcadEntity ent=item as AcadEntity;
    if (ent!=null)
        MessageBox.Show(string.Format("Entity Handle={0}", ent.Handle));
It looks like more .NET programming (not AutoCAD specific) learning is due.
Distinguished Contributor
5 Kudos
Post 2 of 18
Re: How to select a drawing object which is in AutoCAD File from a .Net Applicat
07-17-2012 08:34 AM in reply to: CodeBug
Okay Let's see If I understand:
1- Click on AutoCAD Object (From Within AutoCAD)
2- Display the DBOject Handle or Get that String info and do something with it?
  • One you'll need an Event  I believe it's DatabaseObjectSelected
  • Or PromptSelectionResult
Okay so here's an example from the help file: slightly modified.
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("SelectObjectsOnscreen")]
public static void SelectObjectsOnscreen()
  // Get the current document and database
  Document acDoc = Application.DocumentManager.MdiActiveDocument;
  Database acCurDb = acDoc.Database;
  // Start a transaction
  using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
      // Request for objects to be selected in the drawing area
      PromptSelectionResult acSSPrompt = acDoc.Editor.GetSelection();
      // If the prompt status is OK, objects were selected
      if (acSSPrompt.Status == PromptStatus.OK)
          SelectionSet acSSet = acSSPrompt.Value;
          // Step through the objects in the selection set
          foreach (SelectedObject acSSObj in acSSet)
              // Check to make sure a valid SelectedObject object was returned
              if (acSSObj != null)
                  // Open the selected object for write
                  Entity acEnt = acTrans.GetObject(acSSObj.ObjectId,
                                                   OpenMode.ForWrite) as Entity;
if (acEnt != null) {
//This IS WHERE YOU CAN GET THE HANDLE
//Sorry I'm usually in VB.net so I don't know if this is right.
msgbox("My Entity's Handle is: " & acEnt.Handle);
// Change the object's color to Green acEnt.ColorIndex = 3; } } } // Save the new object to the database acTrans.Commit(); } // Dispose of the transaction } }
 Give it a try. If not we'll keep helping you to you get it working.
Good Luck!
0 Kudos
Post 3 of 18
07-17-2012 11:51 PM in reply to: VB_Autocad_guy
Thanks VB_Autocad_guy! You got it almost right. I want the selected objet's hanlde.
But while I used your code, I am getting the  error below as
The specified module could not be found. (Exception from HRESULT: 0x8007007E)
in Main function at the line
Application.Run(new frmMain());
frmMain is the form name where the button is placed and your code in the button click event.
Any idea why this this error is shown ? So far what I have come to know is
"The error is occurring when the .Net runtime JITs method you're about to step into, because it couldn't find one of the types used by the method."
Any help is appreciated.
215 Kudos
Post 4 of 18
07-18-2012 06:31 AM in reply to: CodeBug
You cannot run the code shown in the other reply in you standalone EXE application. The code can only run inside AutoCAD as NETLOADed .NET DLL.
If you have to do use EXE app, you would look into AutoCAD COM API (COM automation).
37 Kudos
Post 5 of 18
07-18-2012 07:04 AM in reply to: norman.yuan
Imports Autodesk
        SelectHandle()
    End Sub
    Sub SelectHandle()
        Try
        End Try
            Exit Sub
        End If
            MsgBox(item.handle)
        Next
    End Sub
                ssetcheck = True
                Exit For
            End If
        Next
        If ssetcheck Then
        Else
        End If
    End Sub
End Class
(defun botsbuildbots() (botsbuildbots))
5 Kudos
Post 6 of 18
07-18-2012 12:22 PM in reply to: arcticad
Thanks Norman and articad for the help.
Codebug - Hopefully you are up and running now!
0 Kudos
Post 7 of 18
07-18-2012 10:51 PM in reply to: VB_Autocad_guy
Thanks everyone!
VB_Autocad_guy:
I have converted the code by arcticad to C# and is definitly helpful but i'm waiting to see it working!
norman.yuan:
You pushed me back on track. thanks for that!
arcticad:
I have succesfully converted your code to C#.net but stuck at the line
MsgBox(item.handle)     <<<<<<<<<<<<<<< Error line
Next
with error as
'object' does not contain a definition for 'handle'
I am not getting the Handle property for this object.
Please help..
0 Kudos
Post 8 of 18
07-19-2012 06:32 AM in reply to: arcticad
Also, SelectOnScreen without any arguments throws as eror as
No overload for method 'SelectOnScreen' takes '0' arguments
What should be the arguments to this method ?
37 Kudos
Post 9 of 18
07-19-2012 06:59 AM in reply to: CodeBug
just put null in the first argument.
Can you post your c# code?
0 Kudos
Post 10 of 18
07-19-2012 09:48 PM in reply to: arcticad
Hi Arcticad,
This is my code.
internal void SelectHandle()
           if (Globals.AcadDoc == null)
                System.Windows.Forms.MessageBox.Show("Unable to Connect to AutoCAD");
		        return;
	        AcadSelectionSet sset = default(AcadSelectionSet);
            SsetMake(Globals.AcadDoc, "sset");
            sset = Globals.AcadDoc.SelectionSets.Item("sset");
            sset.SelectOnScreen();
	        foreach (object item in sset) {
                System.Windows.Forms.MessageBox.Show(item.handle);
 1. Error in line
Error:
2. Error in line
Error:
Thanks for staying with this!
