.NET
.NET
Valued Mentor
AubelecBE
Message 1 of 6 (255 Views)
How to selec all block only on no frozen and active layer
255 Views, 5 Replies
07-12-2012 05:01 AM
hi all. my code :
Dim editor As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        Try
            Dim values(0) As TypedValue
            values(0) = New TypedValue(DxfCode.Start, "INSERT")
            Dim selFilter As New SelectionFilter(values)
            Dim prompSelRes As PromptSelectionResult = editor.SelectAll(selFilter)
            If prompSelRes.Status = PromptStatus.OK Then
                Dim objSelectSet As SelectionSet = prompSelRes.Value
the only prob is : I want selec all block but not the block on layer frozen, off or not visible...
How i can do that ?
I can check all layer stat on each block.. (i do that already for check each block (name) but i want a solution more easy.)
thanks
*Expert Elite*
Hallex
Message 2 of 6 (251 Views)
Re: How to selec all block only on no frozen and active layer
07-12-2012 05:28 AM in reply to: AubelecBE
Try this filter
  Dim curlay As String = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("clayer").ToString()
                Dim values(3) As TypedValue
                values(0) = New TypedValue(DxfCode.Operator, "<and")
                values(1) = New TypedValue(DxfCode.Start, "insert")
                values(2) = New TypedValue(DxfCode.LayerName, curlay)
                values(3) = New TypedValue(DxfCode.Operator, "and>")
                Dim prompSelRes As PromptSelectionResult = ed.SelectAll(selFilter)
                If prompSelRes.Status <> PromptStatus.OK Then Return
                ed.WriteMessage(vbLf + "{0}", objSelectSet.Count)
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
*Expert Elite*
_gile
Message 3 of 6 (234 Views)
Re : How to selec all block only on no frozen and active layer
07-12-2012 11:24 AM in reply to: AubelecBE
If you really want to use a selection set, you can handle the Editor.SelectionAdded event to filter the blocks:
        public PromptSelectionResult SelectAllVisible(TypedValue[] filter)
            Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
            PromptSelectionResult psr = null;
            try
                ed.SelectionAdded += new SelectionAddedEventHandler(onSelectionAdded);
                psr = ed.SelectAll(new SelectionFilter(filter));
            finally
                ed.SelectionAdded -= new SelectionAddedEventHandler(onSelectionAdded);
            return psr;
        void onSelectionAdded(object sender, SelectionAddedEventArgs e)
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                LayerTable lt = (LayerTable)db.LayerTableId.GetObject(OpenMode.ForRead);
                List<string> layers = new List<string>();
                foreach (ObjectId ltrId in lt)
                    LayerTableRecord ltr = (LayerTableRecord)tr.GetObject(ltrId, OpenMode.ForRead);
                    if (ltr.IsFrozen || ltr.IsHidden || ltr.IsOff)
                        layers.Add(ltr.Name);
                List<int> toRemove = new List<int>();
                SelectionSet ss = e.AddedObjects;
                for (int i = 0; i < ss.Count; i++)
                    BlockReference br = (BlockReference)ss[i].ObjectId.GetObject(OpenMode.ForRead);
                    if (layers.Contains(br.Layer))
                        toRemove.Add(i);
                foreach (int i in toRemove) e.Remove(i);
                tr.Commit();
 Using example:
            TypedValue[] filter = new TypedValue[] { new TypedValue(0, "INSERT") };
            PromptSelectionResult psr = SelectAllVisible(filter);
Anyway, the EditorSelectAll does iterate all the layouts. IMO it's more simple to do it by yourself.
Here's an example using Linq which must be launch from within a transaction and returns an IEnumerable<BlockReference> (lazy sequence):
        public IEnumerable<BlockReference> GetAllVisibleBlocks(Database db)
            List<string> layers = lt
                .Cast<ObjectId>()
                .Select(id => (LayerTableRecord)id.GetObject(OpenMode.ForRead))
                .Where(ltr => ltr.IsFrozen || ltr.IsHidden || ltr.IsOff)
                .Select(ltr => ltr.Name)
                .ToList();
            BlockTable bt = (BlockTable)db.BlockTableId.GetObject(OpenMode.ForRead);
            return bt.Cast<ObjectId>()
                .Select(id => (BlockTableRecord)id.GetObject(OpenMode.ForRead))
                .Where(btr => btr.IsLayout)
                .SelectMany(btr => btr.Cast<ObjectId>())
                .Where(id => id.ObjectClass.DxfName == "INSERT")
                .Select(id => (BlockReference)id.GetObject(OpenMode.ForRead))
                .Where(br => !layers.Contains(br.Layer));
Gilles Chanteau
Valued Mentor
AubelecBE
Message 4 of 6 (206 Views)
07-16-2012 12:17 PM in reply to: _gile
thx.
but can you use vb.net.
i dont like C+.
:smileyhappy:
I dont know this methode for iterate.
*Expert Elite*
_gile
Message 5 of 6 (195 Views)
07-16-2012 02:43 PM in reply to: AubelecBE
I don't like VB :smileywink:
There're free code converters:
http://www.google.fr/#hl=fr&gs_nf=1&cp=10&gs_id=16&xhr=t&q=convert+C%23+to+vb.net&pf=p&output=search...
Using SelectionAdded event handler
        Public Function SelectAllVisible(filter As TypedValue()) As PromptSelectionResult
            Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            Dim psr As PromptSelectionResult = Nothing
            Try
                AddHandler ed.SelectionAdded, AddressOf Me.onSelectionAdded
                psr = ed.SelectAll(New SelectionFilter(filter))
            Finally
                RemoveHandler ed.SelectionAdded, AddressOf Me.onSelectionAdded
            End Try
            Return psr
        End Function
        Private Sub onSelectionAdded(sender As Object, e As SelectionAddedEventArgs)
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim lt As LayerTable = DirectCast(db.LayerTableId.GetObject(OpenMode.ForRead), LayerTable)
                Dim layers As New List(Of String)()
                For Each ltrId As ObjectId In lt
                    Dim ltr As LayerTableRecord = DirectCast(tr.GetObject(ltrId, OpenMode.ForRead), LayerTableRecord)
                    If ltr.IsFrozen OrElse ltr.IsHidden OrElse ltr.IsOff Then
                    End If
                Next
                Dim toRemove As New List(Of Integer)()
                Dim ss As SelectionSet = e.AddedObjects
                For i As Integer = 0 To ss.Count - 1
                    Dim br As BlockReference = DirectCast(ss(i).ObjectId.GetObject(OpenMode.ForRead), BlockReference)
                    If layers.Contains(br.Layer) Then
                        toRemove.Add(i)
                    End If
                Next
                For Each i As Integer In toRemove
                    e.Remove(i)
                Next
                tr.Commit()
            End Using
        End Sub
 Using example:
            Dim filter As TypedValue() = New TypedValue() {New TypedValue(0, "INSERT")}
            Dim psr As PromptSelectionResult = SelectAllVisible(filter)
Using Linq extension methods (must be launched from within a transaction).
        Public Function GetAllVisibleBlocks(db As Database) As IEnumerable(Of BlockReference)
            Dim layers As List(Of String) =
                lt.Cast(Of ObjectId)() _
                .Select(Function(id) DirectCast(id.GetObject(OpenMode.ForRead), LayerTableRecord)) _
                .Where(Function(ltr) ltr.IsFrozen OrElse ltr.IsHidden OrElse ltr.IsOff) _
                .Select(Function(ltr) ltr.Name).ToList()
            Dim bt As BlockTable = DirectCast(db.BlockTableId.GetObject(OpenMode.ForRead), BlockTable)
            Return bt.Cast(Of ObjectId) _
                .Select(Function(id) DirectCast(id.GetObject(OpenMode.ForRead), BlockTableRecord)) _
                .Where(Function(btr) btr.IsLayout) _
                .SelectMany(Function(btr) btr.Cast(Of ObjectId)) _
                .Where(Function(id) id.ObjectClass.DxfName = "INSERT") _
                .Select(Function(id) DirectCast(id.GetObject(OpenMode.ForRead), BlockReference)) _
                .Where(Function(br) Not layers.Contains(br.Layer))
        End Function
Gilles Chanteau
Member
xsfhlzh1
Message 6 of 6 (175 Views)
07-19-2012 06:29 PM in reply to: AubelecBE
        [CommandMethod("t1")]
        public static void Test1()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
                SelectionFilter sf =
                    new SelectionFilter
                        new TypedValue[]
                            new TypedValue(0, "insert"),
                            new TypedValue(8, string.Join(",", layers.ToArray()))
                //ResultList rl =
                //    new ResultList
                //        {0, "insert"},
                //        {8, string.Join(",", layers.ToArray())}
                var res = ed.SelectAll(sf);
 test this code
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
