I have a window that selects some objects (rectangle and two lines, sometimes just a rectangle).
I have seen code that shows how to rotate a single object, but not really much for multiple objects.
Some things I've seen use a "For Each" to get all of the ObjectIds in the selection set and rotate each one. Can someone show me how to create an ObjectIdCollection from a selection set?
I did this, but it just errors out on the rotation:
' If the component doesn't rotate or does a complete 180, do not rotate it If dblCompRot <> 0 Or dblCompRot <> 180 Then Dim myDB As DatabaseServices.Database Dim myEd As EditorInput.Editor Dim compPSR As EditorInput.PromptSelectionResult Dim compSelSet As SelectionSet Dim compObjIDs As ObjectIdCollection Dim comp As Object Dim ssWinX1 As Double, ssWinX2 As Double, ssWinY1 As Double, ssWinY2 As Double, ssWinPt1 As Point3d, ssWinPt2 As Point3d myDB = myDWG.Database myEd = myDWG.Editor ' Select the SMD component using a window compCenter = New Geometry.Point3d(compCenterX, compCenterY, 0) ssWinX1 = compCenterX - ((dblCompLen / 2) + 0.02) ssWinX2 = compCenterX + ((dblCompLen / 2) + 0.02) ssWinY1 = compCenterY - ((dblCompWid / 2) + 0.02) ssWinY2 = compCenterY + ((dblCompWid / 2) + 0.02) ssWinPt1 = New Geometry.Point3d(ssWinX1, ssWinY1, 0) ssWinPt2 = New Geometry.Point3d(ssWinX2, ssWinY2, 0) compPSR = myEd.SelectWindow(ssWinPt1, ssWinPt2) 'compSelSet = compPSR.Value Try 'Dim compPSR As PromptSelectionResult = ed.SelectAll compSelSet = compPSR.Value If compSelSet.Count > 0 Then compObjIDs = New ObjectIdCollection(compSelSet.GetObjectIds) For Each compObjId In compObjIDs comp = compObjId.GetObject(OpenMode.ForWrite) Dim m3d As Matrix3d = Matrix3d.Rotation((dblCompRot * (Math.PI / 180)), Geometry.Vector3d.ZAxis, compCenter) 'Dim ent2 As Entity = tr.GetObject(oid, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite) comp.TransformBy(m3d) Next End If Catch ex As System.Exception MsgBox(ex.ToString) End Try End If End Sub
Mark
if tSSet is declared like that:
Dim tSSet As Autodesk.AutoCAD.EditorInput.SelectionSet
then you can create an objectidcollection in that way:
Dim tObjIdColl As ObjectIdCollection = New ObjectIdCollection(tSSet.GetObjectIds)
HTH, - alfred -
You can try this example as too, cnange entity name to your suit
<CommandMethod("SelCL")> _ Public Sub GetObjectIdsFromSelection() Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim res As PromptSelectionResult res = ed.GetSelection If res.Status <> PromptStatus.OK Then Return End If Dim sset As SelectionSet = res.Value Dim ids As ObjectIdCollection = New ObjectIdCollection() For Each id As ObjectId In sset.GetObjectIds() ' extract just lines and circles without filter: If id.ObjectClass.DxfName = "LINE" Or id.ObjectClass.DxfName = "CIRCLE" Then ids.Add(id) End If Next MsgBox(String.Format("Selected {0} lines and circles", ids.Count)) End Sub
mgorecki Use and try:
Dim compObjIDs as ObjectId()=compSelSet.GetObjectIds()
I think this is where the problem happen.
