.NET
How to restrict AutoCAD by closing or quiting
2 REPLIES 2
243 Views, 2 Replies
Hello Everybody
You might have thought I am wrong to ask such question!!
But the actual situation is I have opened AutoCAD application in WinForm previously I removed the caption of AutoCAD application that time there were no problem but now because of restrictions given by Autodesk in License Agreement I kept AutoCAD's Caption as it is and the problem is started any one can close directly AutoCAD which is loaded in WinForm. I want to restrict user to close only WinForm not AutoCAD Application inside the form.
So please any body have solution for this ??
Thanx in advance
2 REPLIES 2
AutoCAD is designed to be used as a stand-alone application, not embedded as
a control inside of a WinForm.
Dan
wrote in message news:5432520@discussion.autodesk.com...
Hello Everybody
Thanx in advance
Have a look at AutoCAD OEM.
There you have a full autocad that you can embedd in what you want
There's a fee of course, but check it out
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=790640
Hello Everybody
Thanx in advance
”Boost
