.NET
How to respond to a click on Autodesk.AutoCAD.Windows.Pane ?
7 REPLIES 7
Message 1 of 8
834 Views, 7 Replies
Hello !
I'm new to vb.net (moving from VBA) so please excuse me if this sounds
stupid... I'm adding a pane to the status bar an I want to show a popup menu
(or execute a command) after clicking on the pane. This is my code :
Dim DetPane As New Autodesk.AutoCAD.Windows.Pane
DetPane.Text = "DE : "
DetPane.MinimumWidth = 30
DetPane.ToolTipText = "Current Detail : "
DetPane.Enabled = True
DetPane.Visible = True
DetPane.Style = Autodesk.AutoCAD.Windows.PaneStyles.PopUp
Application.StatusBar.Panes.Add(DetPane)
Please, let me know how to create the callback function. Thanks in advance !
7 REPLIES 7
Message 2 of 8
cadMeUp
I am not sure how to hook events in VB, I use mostly use C# for customizing AutoCAD 2008. Looking in the VS object browser a 'Pane' object is derived from 'StatusBarItem' which has a 'MouseDown' event that you can hook into.
The event handler would have this similar signature:
Autodesk.AutoCAD.Windows.StatusBarMouseDownEventHandler.StatusBarMouseDownEventHandler(void (object, Autodesk.AutoCAD.Windows.StatusBarMouseDownEventArgs))
I have very limited experience with VB NET so I can't show you how you would wire it up.
Message 3 of 8
Thanks alot !
This is the code and it is working 🙂 :
AddHandler DetPane.MouseDown, AddressOf OnPaneMouseDown
Sub OnPaneMouseDown(ByVal o As Object, ByVal e As
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbNewLine
+ "Do something man !" + vbNewLine)
End Sub
Message 4 of 8
cadMeUp
That's great to hear! I am going to keep your sample for my possible future use! It gives me a good example of how to hook an event in VB.
Message 5 of 8
stevenh0616
Anyone figure out how to make this work in 2013? Pane.MouseDown does not seem to exist? Please help!!
Steve Hill
Civil Designer / .NET Developer
AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn
Please select the Accept this solution button if my post solves your issue or answers your question.
Message 6 of 8
Are you sure?
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 7 of 8
Well I see that it's there under StatusBarItem, but it gives an error under Pane....
If I Have code like this
DetPane.MouseDown += New StatusBarMouseDownEventHandler(AddressOf OnAppMouseDown)
I get this... Could I be missing an Import??
Here are my imports...
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports cadApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports cadDocExt = Autodesk.AutoCAD.ApplicationServices.DocumentExtension
Imports Autodesk.AutoCAD.Windows
Steve Hill
Twitter | LinkedIn
Message 8 of 8
Sub OnPaneMouseDown(ByVal o As Object, ByVal e As StatusBarMouseDownEventArgs)
    Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(vbNewLine + "Do something man !" + vbNewLine)
End Sub
<CommandMethod("MyCommand")> _
Public Sub MyCommand() ' This method can have any name
End Sub
Expert Elite Member
”Boost
