.NET
Valued Mentor
AubelecBE
Message 1 of 3 (493 Views)
How to remove entity from BlockTableRecord ?
493 Views, 2 Replies
02-23-2012 05:23 AM
'Gestion Bloc en mémoire
            Dim BlocSpace As BlockTable         'Coll des BlockDef en ModelSpace
            Dim BlocDef As BlockTableRecord     'Def du bloc
            Try
                tr = db.TransactionManager.StartTransaction()
                BlocSpace = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
                If BlocSpace.Has(Tableau.NomBlocDessin) = False Then
                    'création d'un nouveau Def
                    BlocDef = New BlockTableRecord
                    BlocDef.Name = Tableau.NomBlocDessin
                    'Open.ForWrite
                    BlocSpace.UpgradeOpen()
                    'Ajout à la base et mémorisation de l'ID pour l'add sur le dessin
                    ' blocref = new blockreference(point3d,id)
                    Dim BlocDefId As ObjectId = BlocSpace.Add(BlocDef)
                    'Ajout au dessin
                    tr.AddNewlyCreatedDBObject(BlocDef, True)
                Else
                    'récupération de la def.
                    BlocDef = tr.GetObject(BlocSpace.Item(Tableau.NomBlocDessin), OpenMode.ForWrite)
                    'suppression de tous les élements dans la def.
                End If
            Catch ex As Exception
                MsgBox(ex.ToString, vbOKOnly, "Erreur système dans ClassFichier.CréationTableau")
            Finally
                tr.Commit()
                tr.Dispose()
            End Try
now i have a BlockTableRecord in car BlocDef.
How i can delete all entity in this ?
I want to create a new order in the blocdef but i dont want delete the Blockreference. so i dont 'purge'
Thx.
_gile
Message 2 of 3 (487 Views)
Re : How to remove entity from BlockTableRecord ?
02-23-2012 05:45 AM in reply to: AubelecBE
You can iterate the BlockTableRecord, open each entity and erase it.
Salut,
Tu peux parcourir le BloctTableRecord ouvrir chaque entité et l'effacer.
foreach (ObjectId id in BlocDef)
    Entity ent = (Entity)tr.GetObject(id, OpenMode.ForWrite);
    ent.erase();
Gilles Chanteau
Valued Mentor
AubelecBE
Message 3 of 3 (473 Views)
02-23-2012 07:31 AM in reply to: _gile
ah ok Thanks i have to try it tomorrow.
If i delete all BlockReference and purge the DefBloc: it is much fast no ?
