.NET
How to reject layer deleting
1 REPLY 1
400 Views, 1 Reply
I want to lock my layer from deleting.
I did it as for object:
    public class NonErasableLayer : ObjectOverrule
        public NonErasableLayer()
            this.SetCustomFilter();
        protected override void Dispose(bool value)
            this.SetNoFilter();
            base.Dispose(value);
        public override bool IsApplicable(Autodesk.AutoCAD.Runtime.RXObject overruledSubject)
            if (overruledSubject == null)
                return false;
            return (overruledSubject is LayerTableRecord);
        public override void Erase(DBObject dbObject, bool erasing)
            if (dbObject is LayerTableRecord)
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\nLAYER IS LOCKED.\n");
            throw new Autodesk.AutoCAD.Runtime.Exception(ErrorStatus.NotApplicable);
Then I set overrule for Drawable objects:
     ObjectOverrule.AddOverrule(RXClass.GetClass(typeof(Drawable))...
When I run it I saw my message from Erase method but... layer is deleted.
This method works fine for any objects as Line or Circle, but doen't work for layer.
How I can reject layer deleting?
Pavel.
1 REPLY 1
jeff
In link below is a similar thread and was to store the LayerTableRecord's ObjectIDs as Hard Pointers.
Would use the advice to store in Owners ExtensionDictionary
http://www.theswamp.org/index.php?topic=41870.msg469858#msg469858
You can also find your answers @ TheSwamp
”Boost
