In AutoCAD Electrical on the "About Assigning Catalog Information to Components" section there is a section about using an external database application:
"AutoCAD Electrical provides a means to bypass its internal catalog part number look-up and temporarily pass control to your custom catalog part number selection application. In the Insert/Edit dialog box, Catalog Data section, click Lookup. But instead of immediately accessing the appropriate catalog look-up table, AutoCAD Electrical passes control to your application. You make the MFG/CAT/ASSYCODE selection in your own database program. Your application formats your selection and passes it back to AutoCAD Electrical."
Does anyone know how to actually implement this?
Thank you.
Solved by AdrianSaf. Go to Solution.
I found how to do it thanks to this: http://forums.autodesk.com/t5/AutoCAD-Electrical-General/Customize-part-catalog-selection-window/td-....
In the add-in you ca define a custom lisp function method and them you can call it from wd_xcat.lsp (or any lsp you set in the enviroment file).
