You'll have to excuse the resident ignoramus, as it seems
that sometimes he just can't resist making a complete fool
of himself.
You can place your geometry in an anonymous block, and
then insert it. That allows the user to move/scale/rotate or
erase it, but not stretch it.
In AutoCAD 2010, you can also use the new Overrule API
to restrict how certain objects can be edited without using
blocks, but that will only work in AutoCAD 2010 or later, and
only if your application is loaded.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:6165358@discussion.autodesk.com...
i don't want to let user change the shape of an object which was drawn
before. When i select an entity in Auto cad it will get dashed and get
Handle so STRETCH will change the shape of an entity. i want to prevent
this.
