.NET
dreamwtx
Message 1 of 9 (577 Views)
How to pass parameter in interface to the programe of .dll file using c#?
577 Views, 8 Replies
03-14-2012 11:51 PM
I  have developped  the  interface using c#,i want to turn off or on the layer according to the parameter in interface.
now i have carried out turn off or on a specified layer using a .dll file. but how i can connect the parameter in interface to the program in .dll file .thanks
MarkPendergraft
Message 2 of 9 (556 Views)
Re: How to pass parameter in interface to the programe of .dll file using c#?
03-15-2012 07:33 AM in reply to: dreamwtx
What interface did you develop?  Is it a ribbon? tool palette? Is it an external program?
-Mark
dreamwtx
Message 3 of 9 (538 Views)
03-15-2012 06:06 PM in reply to: MarkPendergraft
-Mark
yes ,it is anexternal program. the interface is developped using c#.
MarkPendergraft
Message 4 of 9 (534 Views)
03-15-2012 08:00 PM in reply to: dreamwtx
If it's an external program, then you need to use the COM API to access functionality inside autocad from your external program.
Take a look here for someone with the same idea:
http://forums.autodesk.com/t5/NET/Stand-alone-applications/m-p/2513610/highlight/true#M15108
You can also search for stand alone applications.  There has been a lot of discussion on this type of thing, but it's not something I've ever explored.
-Mark
dreamwtx
Message 5 of 9 (528 Views)
03-15-2012 10:07 PM in reply to: MarkPendergraft
Thank you
Hallex
Message 6 of 9 (523 Views)
03-15-2012 10:21 PM in reply to: dreamwtx
Show us your code you get started with
maybe it will be more effective
~"J"~
dreamwtx
Message 7 of 9 (515 Views)
03-16-2012 12:48 AM in reply to: Hallex
  2. using System;
    using System.Collections.Generic;
    using System.ComponentModel;
    using System.Data;
    using System.Drawing;
    using System.Linq;
    using System.Text;
    using System.Windows.Forms;
    using System.Runtime.InteropServices;
    using Autodesk.AutoCAD.Interop;
    using Autodesk.AutoCAD.Interop.Common;
    using Autodesk.AutoCAD;
    using System.IO;
    //using Autodesk.AutoCAD.ApplicationServices;
    //using Autodesk.AutoCAD.DatabaseServices;
    //using Autodesk.AutoCAD.Runtime;
    //using TurnLayerOff;
    namespace Demo
        public partial class Form1 : Form
            private AcadApplication a;//声明AutoCAD对象
            public Form1()
                InitializeComponent();
            private void button1_Click(object sender, EventArgs e)
                a = new AcadApplicationClass();
                a.Visible = true;
                string strFileName = "C:\\G4P4-S01.dwg";
                a.Application.Update();//更新显示
                a.Application.Documents.Open(strFileName, false, 1);
                //Autodesk.AutoCAD.Interop.AcadDocument aDocument;
                //Autodesk.AutoCAD.Interop.Common.AcadLayers acDoc;
                //a.ActiveDocument.Layers.Item("IN_SWGEAR_CAB_USED").LayerOn=false;
                //AcadDocument acDocComObj;
                //acDocComObj = acAppComObj.ActiveDocument;
                // Optionally, load your assembly and start your command or if your assembly
                // is demandloaded, simply start the command of your in-process assembly.
                a.ActiveDocument.SendCommand("(command " + (char)34 + "NETLOAD" + (char)34 + " " +
                                        (char)34 + "c:/myapps/mycommands.dll" + (char)34 + ") ");
                TurnLayerOff.Class1.TurnLayerOff(textBox2.Text);
                a.ActiveDocument.SendCommand("TurnLayerOff");
  3.
        TurnLayyerOff  is .dll file.but i can't pass textBox2.text to the ,dll file.
Hallex
Message 8 of 9 (508 Views)
03-16-2012 02:49 AM in reply to: dreamwtx
You may want to use direct access to all
AutoCAD objects this way instead:
            a.Visible = true;
            string strFileName = @"C:\G4P4-S01.dwg";
            AcadApplication acad = (AcadApplication)a as AcadApplication;
            acad.WindowState = AcWindowState.acMax;
            AcadDocument adoc = (AcadDocument)acad.ActiveDocument as AcadDocument;
            AcadUtility acutil = (AcadUtility)adoc.Utility as AcadUtility;
            string layername = textBox2.Text;
            acutil.Prompt(string.Format("\nLAYER SELECTED\t{0}",layername));
            AcadLayers aclayers = (AcadLayers)adoc.Layers;
            AcadLayer aclayer = aclayers.Item(layername) as AcadLayer;
            if (aclayer == null)
                MessageBox.Show("Layer \"{0}\" does not exist, try another layer name");
                this.textBox2.Select();
                this.textBox2.Text = string.Empty;
                return;
            if (aclayer.ObjectID == adoc.ActiveLayer.ObjectID)
                MessageBox.Show("This is active layer, program exiting...");
                return;
            if (aclayer.LayerOn)
                aclayer.LayerOn = false;
            acutil.Prompt(string.Format("\n\tLAYER \"{0}\" IS OFF", layername));
~'J'~
dreamwtx
Message 9 of 9 (455 Views)
03-19-2012 08:59 PM in reply to: dreamwtx
there is an error  "HRESULT:0x80010001 (RPC_E_CALL_REJECTED"
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
