I am not able to open a new window if a window is opened in Inventor.
The scenario is when we open a wpf window in Inventor and if we minimize that window and want to open other window then the background window of Inventor get freezes and we are not able to access other window options in Inventor.
So I want to work on background window even if a window is opened in Inventor.
Here I attached the code snippet of showing window.
Solved by _gile. Go to Solution.
This is precisely the behavior of a modal dialog box (and typically, modal dialog boxes do not have maximize and minimize buttons).
Window.ShowDialog() opens the window as modal. If you want to be able to open more than one dialog box at the same time, you should show them as modeless with the Window.Show() method.
Readr this topic for more informations about WPF dialog boxes.
