.NET
How to open Modal MFC dialog in Managed C++
0 REPLIES 0
Message 1 of 1
massoudshakeri
420 Views, 0 Replies
I have a simple mix-managed project, in which one managed and one unmanaged command is created. A simple Dialog derived from CAcUiDialog is added to the project. Both commands, create and show that dialog modelessly, and it works fine.
But when I change the code to create the dialog using DoModal() in both commands, the dialog shows for unmanaged command, but upon running the managed command, Autocad stalls.
How can I create a Modal unmanaged dialog in Managed command?
With thanks in advance
0 REPLIES 0
”Boost
