.NET
How to open database from an open drawing
4 REPLIES 4
499 Views, 4 Replies
Once I have the dwg open how do I get to the database?
        Dim AcadApp As Object = Nothing
        Dim AcadDoc As Object = Nothing
        Try
            AcadApp = GetObject(, "AutoCAD.Application.18")
        Catch ex As Exception
            AcadApp = CreateObject("AutoCAD.Application.18")
        End Try
        AcadApp.Visible = False
        Try
            AcadDoc = AcadApp.Documents.Open("C:\Users\PAUL\Desktop\B-03-J-H135.dwg", True)
            Exit Sub
        End Try
        Dim MyDb As Database = AcadApp.DocumentManager.MdiActiveDocument.Database
4 REPLIES 4
Alfred.NESWADBA
You have it, where is the question?
You have it here:
That <MyDb> is the database of your currently active drawing!
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
norman.yuan
From he code yoy showed (and also the code you showed in previous post), it looks like you are doing Stabdalone EXE apllication.
If so, you can forget about setting reference to acdbmgd.dll and acmgd.dll and using APIs exposed in these 2 assemblies: they CANNOT be used outside AutoCAD in a standalone app. End of story.
You have to use COM APIs. The code would be sililar to VBA code.
Norman Yuan
Drive CAD With Code
in reply to: norman.yuan
Well then tell me how. Because there are other apps out there doing what I need to do. According to the docs from ACAD, that is what those DLL's are for.
Hallex
As you're mentioned above you HAVE NOT use dll libraries
in your .exe aplppliction at all,
so forget about them, indeed
Use just VBA like syntax and nothiing else, in the short words
~'J'~
”Boost
