.NET
Showing results forĀ
Did you mean:Ā
How to open autocad.exe in C# , PLEASE HELP!
25 REPLIES 25
Message 1 of 26
7651 Views, 25 Replies
I am using Visual.net 2008 with autocad.net API, autocad2010, windows 7 home
right now, i want to start autocad.exe, and draw some lines in it, by using C# WindowsFormsApplication, not  C# Class Library
still i cannot start autocad.exe
I hope to open cad by autocad.net API, not ObjectARX or others
I am a new one,  please HELP ME
thanks very very much !
25 REPLIES 25
Message 2 of 26
There is no exe autocad, you mean acad.exe?
You cant program in autocad through windows forms with just opening acad.exe with out ObjectARX
Message 3 of 26
Hallex
If you want to don't add any reference to acad's libraries
in this case just one way to do it is using late-binding to AutoCAD
There is a ton of code to do this work
Message 4 of 26
Hallex
Here are 2 files were written on vb.net
See if this will be working fror you
Message 5 of 26
in reply to: Hallex
Thanks very much ! really appreciate your great help ~
actually i work it out by using C# library
Message 6 of 26
Hallex
Create Wndws Forms Application project
Name it AcadTestExe
Add form Form1 to project
Drop on form OpenFileDialog, texbox and button
Keep default names for all controls
Add class ReflectionCommands.cs
Copy all codes accodingy to classes, then hit F5
~'J'~
Message 7 of 26
in reply to: Hallex
Dear Hallex, you are genius!!!
I tried your codes, and it works very well~
Thank for your help, It's really great~
althought I cannot figured out how you fix it without adding any CAD liraries or dll
I am a new one in cad developping , these days I kept searching for any useful book or documents
still there is no result
Can you give me some advice for learning cad with C# ? Is there any useful documents for me ?
PS: I can draw circle by your  incredible codes, Could you please tell me how to draw a ARC ?
Message 8 of 26
Hallex
C'mon
This is very simple code
Glad you like it
This project does not require any
CAD library
I tested it on A2009-2010 Win7
Will be back
~'J'~
Message 9 of 26
in reply to: Hallex
your code is incredible simple, I enjoy it
I cannot understand you until now
with your help, I figured it how to draw an arc
thanks ~~~~~~
and please give me some advice Smiley Tongue
Message 10 of 26
in reply to: Hallex
dear Hallex:
   I use your code to draw some lines in cad,
  It is ok in WIN7 64bit + AUTOCAD2008 and WinXP + AUTOCAD2004
 but errors happened in WinXP + AUTOCAD2008
 my code is :
for (int k = 1; k < iHH.OutHHXY.Row - 1; k++)
pt2[0] = iHH.OutHHXY[k, 0];
pt2[1] = iHH.OutHHXY[k, 1];
drawLineInObject(oSpace, pt1[0], pt1[1], pt2[0], pt2[1], "0");
pt1[0] = pt2[0];
pt1[1] = pt2[1];
The error happened in these lines:
object oLine = oBlock.GetType().InvokeMember("AddLine", BindingFlags.InvokeMethod, null, oBlock, pts);
oLine.GetType().InvokeMember("Layer", BindingFlags.SetProperty, null, oLine, new object[] { layer });
oLine.GetType().InvokeMember("Update", BindingFlags.InvokeMethod, null, oLine, null);
BUT , if I debug the loops one by one, It runs well. I am so confused~
please help me ~~
Thanks very much !!!
1
Message 11 of 26
Hallex
Try attached code it I rewrote it completely
I added some other things take a look at
the additional functions
Message 12 of 26
Hallex
I wan't to do your homework sorry
In the attached file all is enough for
the basic operations
you have to read some books
about C# reference for more
Message 13 of 26
in reply to: Hallex
Smiley Embarassed Dear Hallex, Thanks very much for your patience andexcellent codes
I am reading some articles and books, I am sorry to cost you much timeSmiley Tongue
Message 14 of 26
Hallex
You're welcome
Just a hint:
Don't forget to rewrite drawLineInObject function
easier yet to use double[] as start and end points as
arguments
Something like:
{code}
public static object DrawLine (object oBlock, double[] p1, double[] p2, string layer)
// ...  the rest portion of your code is goes here.....
return oLine;
}{code}
Message 15 of 26
in reply to: Hallex
Dear Hallex:
I read your code and test in Win7 with .net2008 cad2010, runs very well ~
but in winXP .net2008 cad2008, error happens
it says cannot find the following files:
at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start(String fileName)
at AcadTestExe.ReflectionCommands.TestACAD(String fname) in F:........
at AcadTestExe.Form1.button1 Click(Object sender. EventArgs e) in F:.......
Dear Hallex, should I add some libraries in winXP?
I am a little confused,
what language do you think is fit for me to learn cad devlopping?
ObjectARX, or VBA, or visual Lisp, or C# ?
can you introduce some reference book for me ?
right now I am more familiar with C#, C++ and matlab
Thanks for your patience and incredible codes~~~
Message 16 of 26
Hallex
On the quick glance it may occurs by User Permission
See here for more:
http://msdn.microsoft.com/en-us/library/system.diagnostics.process.process(v=vs.80).aspx
Message 17 of 26
in reply to: Hallex
Dear Hallex:
I test your code in anther computers
It runs well in WinXP and Win7 64bit, cad2004, 2007, 2008, 2010
you are genius, Hallex
I read many articles
and never see cad C# code without any libraries
your defined AcadApp and AcadDoc as Object
Is it the reason that can runs well in different OS and CAD ?
Message 18 of 26
Hallex
There is no magic in my crappy codes
just well-known runtime methods nothing else
Please see here for more:
http://msdn.microsoft.com/en-us/library/system.reflection(v=vs.80).aspx
Hey, cease to praise me, I same stupid, as my gray-haired @$$ šŸ™‚
~'J'~
Message 19 of 26
in reply to: Hallex
Dear Hallex:
I never found cad C# code as powerful as yours which even need not dll or com
so I admire you Smiley Tongue
I am reading cad VBA now, and take a look at the MSDN web link you gave me
I know your code use some VBA Method, just like AddLine, Open...
My question is :
how do you know the parameters of using vba method?
For example: object AcDoc = AcadDocs.GetType().InvokeMember("Open", BindingFlags.InvokeMethod, null, AcadDocs, args, null);
you define args: args[0] = fname;(file path and name)  args[1] = false;(can write dwg)
I saw in vba is :ThisDrawing.Application.Documents.Open "c:\1.dwg"
how do you know need fname together with false?
where can I find the rules?
all in C# library reference, reflection???
Message 20 of 26
Hallex
No, all these arguments in AutoCAD Help file
That is a lot of work to digg it from there
Say, open VBA editor in AutoCAD by Alt+F11
Then in console add dummy Sub say:
{code}
Public sub Test()
type Open in here, then select a word Open
by double click on them and press F1
See then all arguments in the Help file
End sub
 {code}
Hint:
To convert any arguments to numeric values:
Open 'Immediate Window' in same editor and type here
any of AutoCad's constants preceded with question mark like this:
?acActiveViewPort
 or
?acSelectionSetAll
or
??acselectionSetCrossingPolygon
or
?acMiddleCenter ETC, ETC
Then press Enter
You should see a numeric equivalent of this constant
 in the same window next line below
So nothing smart it's just a lot of work, you have to digg deeper yourself
ā€Boost
