.NET
Leimhu
Message 1 of 24 (1,768 Views)
How to open autocad.exe in C# , PLEASE HELP!
1768 Views, 23 Replies
02-05-2012 12:13 AM
I am using Visual.net 2008 with autocad.net API, autocad2010, windows 7 home
right now, i want to start autocad.exe, and draw some lines in it, by using C# WindowsFormsApplication, not  C# Class Library
still i cannot start autocad.exe
I hope to open cad by autocad.net API, not ObjectARX or others
I am a new one,  please HELP ME
thanks very very much !
Valued Contributor
kob4lt
Message 2 of 24 (1,750 Views)
Re: How to open autocad.exe in C# , PLEASE HELP!
02-05-2012 02:12 AM in reply to: Leimhu
There is no exe autocad, you mean acad.exe?
You cant program in autocad through windows forms with just opening acad.exe with out ObjectARX
Hallex
Message 3 of 24 (1,743 Views)
02-05-2012 03:14 AM in reply to: Leimhu
If you want to don't add any reference to acad's libraries
in this case just one way to do it is using late-binding to AutoCAD
There is a ton of code to do this work
Hallex
Message 4 of 24 (1,739 Views)
02-05-2012 05:43 AM in reply to: Leimhu
Here are 2 files were written on vb.net
See if this will be working fror you
Leimhu
Message 5 of 24 (1,705 Views)
02-06-2012 01:54 AM in reply to: Hallex
Thanks very much ! really appreciate your great help ~
actually i work it out by using C# library
Hallex
Message 6 of 24 (1,678 Views)
02-06-2012 08:17 AM in reply to: Leimhu
Create Wndws Forms Application project
Name it AcadTestExe
Add form Form1 to project
Drop on form OpenFileDialog, texbox and button
Keep default names for all controls
Add class ReflectionCommands.cs
Copy all codes accodingy to classes, then hit F5
~'J'~
Leimhu
Message 7 of 24 (1,654 Views)
02-06-2012 06:26 PM in reply to: Hallex
Dear Hallex, you are genius!!!
I tried your codes, and it works very well~
Thank for your help, It's really great~
althought I cannot figured out how you fix it without adding any CAD liraries or dll
I am a new one in cad developping , these days I kept searching for any useful book or documents
still there is no result
Can you give me some advice for learning cad with C# ? Is there any useful documents for me ?
PS: I can draw circle by your  incredible codes, Could you please tell me how to draw a ARC ?
Hallex
Message 8 of 24 (1,646 Views)
02-06-2012 09:00 PM in reply to: Leimhu
C'mon
This is very simple code
Glad you like it
This project does not require any
CAD library
I tested it on A2009-2010 Win7
Will be back
~'J'~
Leimhu
Message 9 of 24 (1,643 Views)
02-06-2012 11:07 PM in reply to: Hallex
your code is incredible simple, I enjoy it
I cannot understand you until now
with your help, I figured it how to draw an arc
thanks ~~~~~~
and please give me some advice :smileytongue:
Leimhu
Message 10 of 24 (1,639 Views)
02-07-2012 12:27 AM in reply to: Hallex
dear Hallex:
   I use your code to draw some lines in cad,
  It is ok in WIN7 64bit + AUTOCAD2008 and WinXP + AUTOCAD2004
 but errors happened in WinXP + AUTOCAD2008
 my code is :
for (int k = 1; k < iHH.OutHHXY.Row - 1; k++)
pt2[0] = iHH.OutHHXY[k, 0];
pt2[1] = iHH.OutHHXY[k, 1];
drawLineInObject(oSpace, pt1[0], pt1[1], pt2[0], pt2[1], "0");
pt1[0] = pt2[0];
pt1[1] = pt2[1];
The error happened in these lines:
object oLine = oBlock.GetType().InvokeMember("AddLine", BindingFlags.InvokeMethod, null, oBlock, pts);
oLine.GetType().InvokeMember("Layer", BindingFlags.SetProperty, null, oLine, new object[] { layer });
oLine.GetType().InvokeMember("Update", BindingFlags.InvokeMethod, null, oLine, null);
BUT , if I debug the loops one by one, It runs well. I am so confused~
please help me ~~
Thanks very much !!!
1
