.NET
How to monitor the vertex modify of a polyline
2 REPLIES 2
lapiseast
372 Views, 2 Replies
when modifying a vertex of a polyline using mouse drag, i need to monitor this event and then modify the other properties of the line.
i could react the change through the DatabaseReactor::objModified event , but in this method it is forbidden to modify the line again ( to avoid the infinite circulation ).
Any other place could i react the vertex modify?
2 REPLIES 2
in reply to: lapiseast
Add the id of the pline to an (global) IdArray (there's an ObjectIdArray im
ARX, so i guess there's something similar in .NET.
Check that idArray in objClosed and do your stuff.
/Matt
wrote in message news:5420797@discussion.autodesk.com...
I correct myself
commandEnded is the place to change the pline
/Matt
"Matt" wrote in message
news:5428508@discussion.autodesk.com...
/Matt
”Boost
