.NET
How to modify raster reference path
3 REPLIES 3
rtejada
1029 Views, 3 Replies
Hi everybody
I need to modify a bunch of AutoCAD raster image reference paths on diferent dwg files.
I am able to display image path property using the code below.
How can I modify the image reference path?
I will appreciate any help
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports Autodesk.AutoCAD.DatabaseServices
Public Sub LoadImageProperties(ByVal localFileName As String)
Dim db As New Database
db.ReadDwgFile(localFileName, IO.FileShare.ReadWrite, False, Nothing)
Dim tm As TransactionManager = db.TransactionManager
Dim rasterImageDef As RasterImageDef
Dim dictEntry As System.Collections.DictionaryEntry
Dim nod As DBDictionary
Dim imageDict As DBDictionary
nod = CType(tm.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead, False), DBDictionary)
imageDict = CType(tm.GetObject(nod.GetAt("ACAD_IMAGE_DICT"), OpenMode.ForRead, False), DBDictionary)
Dim imagePath As String
For Each dictEntry In imageDict
Dim obj As DBObject
obj = tm.GetObject(CType(dictEntry.Value(), ObjectId), OpenMode.ForRead, False)
'the next is needed to get the raster image path
If obj.GetRXClass.IsDerivedFrom(Autodesk.AutoCAD.Runtime.RXClass.GetClass(GetType(RasterImageDef))) Then
'create a RasterImageDef wrapper
rasterImageDef = CType(Autodesk.AutoCAD.Runtime.DisposableWrapper.Create(GetType(RasterImageDef), obj.UnmanagedObject, False), RasterImageDef)
imagePath = rasterImageDef.SourceFileName
msgbox(imagePath)
Next
ta.Commit()
ta.Dispose()
db.Dispose()
End Sub
3 REPLIES 3
kean.walmsley
in reply to: rtejada
Hi Raul,
I had to do a few things to get your code to work...
You're missing a line (which I'm guessing is there in your original code, somewhere):
Dim ta As Transaction = tm.StartTransaction
You also need to open the RasterImageDef object for write, rather than read. You can do that in the GetObject() call or (and this following approach is better) call UpgradeOpen() once you've established it's a raster image definition.
I'd also recommend not using the default Database constructor, but passing (false,true) as arguments.
Hopefully that's enough to get this working...
Kean
Kean Walmsley
Platform Architect & Evangelist, Autodesk Research
Blog | Twitter
rtejada
Hi Kean
I fix the code per your suggestions thanks, but still getting the exception error when assigning the rasterimageDefinition.Sourcefilename or ActiveFileName.
I do not know what you mean by "I'd also recommend not using the default Database constructor, but passing (false,true) as arguments."
Private Sub Repath()
Dim tm As Transaction = db.TransactionManager.StartTransaction()
nod = CType(tm.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForWrite, False), DBDictionary)
imageDict = CType(tm.GetObject(nod.GetAt("ACAD_IMAGE_DICT"), OpenMode.ForWrite, False), DBDictionary)
Dim obj As DBObject
obj = tm.GetObject(CType(dictEntry.Value(), ObjectId), OpenMode.ForWrite, False)
obj.UpgradeOpen()
try
'this next does not work, I get a exception of the type "eFileAccessErr" in any of the 2 next lines
rasterImageDef.SourceFileName = "c:\test.jgp"
rasterImageDef.ActiveFileName = "c:\test.jpg"
Catch ex As Exception
End Try
Next
tm.Commit()
db.Save()
tm.Dispose()
db.Dispose()
End Sub
kean.walmsley
Hi Juan,
Here's your code with the modifications I made to test... it worked just fine on AutoCAD 2007.
Kean
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Namespace ImageTest
  Public Class ImageCmds
    ' Must have UsePickSet specified
    "TEST")> _
    Public Sub LoadImageProperties()
      Dim db As New Database(False, True)
      'This DWG file contains images attached from C:\My Documents
      db.ReadDwgFile("c:\temp\testimage.dwg", IO.FileShare.ReadWrite, False, Nothing)
      Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = db.TransactionManager
        Dim obj As DBObject
          MsgBox(imagePath)
          'Strip off the filename, looking for the lask backslash, repath it to the temp folder
          imagePath = "C:\temp\" + imagePath.Substring(imagePath.LastIndexOf(Chr(92)) + 1)
          'Make sure the def object is open for write, then set the filename to the new location
          rasterImageDef.UpgradeOpen()
          rasterImageDef.SourceFileName = imagePath
          'Just to double-check, let's get the filename and show it
          MsgBox(imagePath)
      Next
      ta.Commit()
      ta.Dispose()
      db.Dispose()
    End Sub
  End Class
End Namespace
Kean Walmsley
Blog | Twitter
”Boost
