.NET
How to modifie datas in Xrecord ?
3 REPLIES 3
410 Views, 3 Replies
After to create Xrecord, How to modifie datas in
Xrecords ?.
Dim XrecDict As Xrecord
Try
    XrecDict =
CType(Trans.GetObject(SSDict.GetAt("APP_UNITS"), OpenMode.ForWrite),
Xrecord)
    If XrecDict.Data.AsArray.Length
> 0 Then
        ReDim
XrecList(XrecDict.Data.AsArray.Length - 1)
        Dim
i As Integer
        Dim ResBuf As
TypedValue
        For i = 0 To
    ResBuf = XrecDict.Data.AsArray(i)
    XrecList.SetValue(String.Format("{0}", ResBuf.Value),
i)
size=2>        Next
    End If
.....How to modifie datas in Xrecords
Danks ! Alain
3 REPLIES 3
You cannot directly modify the data in an Xrecord.  You
will need to create a new ResultBuffer, add the desired TypedValue objects to
it, and assign it to the Data property of the Xrecord.
Bobby C.
Jones
http://www.acadx.com
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Xrecords ?.
Try
    XrecDict =
Xrecord)
    If
XrecDict.Data.AsArray.Length > 0 Then
        ReDim
size=2>        Dim i As
Integer
        Dim ResBuf
As TypedValue
        For i = 0
To XrecDict.Data.AsArray.Length - 1
i)
size=2>        Next
    End If
Danks !
Alain
According to this and similar articles, I have been trying to edit xrecord values by changing the appropriate data values.
However, the value does not stay after trans.commit.
Public Sub SaveInfo(Prefs As Autodesk.AutoCAD.DatabaseServices.DBDictionary, Trans As Autodesk.AutoCAD.DatabaseServices.Transaction, sBlockLabel as String)
Dim rXrec As DatabaseServices.Xrecord = Trans.GetObject(Prefs.GetAt(sBlockLabel), Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, True, True)
dim ResBuf as New DatabaseServices.ResultBuffer(New DatabaseServices.TypedValue(1, me.ToString))
rXrec.Data = ResBuf
Prefs.SetAt(sBlockLabel, rXrec)'likely redundant
End Sub
here with a proven functional connection to its dictionary, and transaction, is some of my edit code. Previous value being unnecessary, are skipped at this point, but the record exists so cannot be re-added to dictionary.
Is there some Other step for editing i need?
As a note, perhaps i see this the wrong way coming from a sql background.
Most Data manipulations in such areas area done with make the change and update the database/table.
Perhaps in this one you have to delete and remake the xrecord the data was atached too?
This process i not directly referenced in any labs i have found so far.
”Boost
