.NET
how to maike an Entity IsReadEnabled?
3 REPLIES 3
lapiseast
282 Views, 3 Replies
Entity ent = null ;
ent =(Entity)obj ; //as known,now,ent.IsReadEnabled=true and ent.IsWriteEnabled=true
//now,after use ent done ,we'll find ent.IsReadEnabled=false and ent.IsWriteEnabled=false
question: how to make ent.IsReadEnabled or ent.IsWriteEnabled true again??
3 REPLIES 3
in reply to: lapiseast
ent.DowngradeOpen() and ent.UpgradeOpen() can help you.
lapiseast
downgradeopen() must be used while ent is open for write(means ent.IsWriteEnabled=true);
upgradeopen() must be used while ent.IsReadEnabled=true;
but while ent.IsReadEnabled is false,how to make it true ? Message was edited by: lapiseast
I do not understand your's problem. Try this code:
[code]
// Define Command "TestOpen"
[CommandMethod("TestOpen")]
static public void TestOpen()
Document doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
PromptEntityResult rse = ed.GetEntity("\nSelect Entity: ");
if (rse.Status == PromptStatus.OK)
using (Transaction tr = doc.TransactionManager.StartTransaction())
Entity ent = (Entity) tr.GetObject(rse.ObjectId,OpenMode.ForRead);
ed.WriteMessage("\nent.IsReadEnabled = {0}",ent.IsReadEnabled);
ed.WriteMessage("\nent.IsWriteEnabled = {0}",ent.IsWriteEnabled);
ent.UpgradeOpen();
ent.DowngradeOpen();
tr.Commit();
[/code]
Results:
[code]
Command: testopen
Select Entity:
ent.IsReadEnabled = True
ent.IsWriteEnabled = False
ent.IsWriteEnabled = True
[/code]
”Boost
