Hi All,
Im using C#.net for dll creation.I have successfully modified all AutoCAD 2013 dll's to work in AutoCAD 2017 .But i got a problem with DLL loading time in AutoCAD.I use a batch file to copy all dll's to "%APPDATA%Autodesk\ApplicationPlugins\ "folder then i launch AutoCAD through the same batch file .But when its launched it is loading dll's one by one, so its taking more time.In AutoCAD 2013 also i had the same issue.But IExtensionApplication call fixed the issue.I use PackageContents.xml As shown below,
<ComponentEntry
AppName="Test"
ModuleName="./Contents/Test.dll"
AppDescription="Test-ABC"
startupcommand ="True" >
<Commands GroupName="PLUGINS">
<Command Local="Test" Global="Test" startupcommand ="True"/>
</Commands>
</ComponentEntry>
So ,What i need to do inorder to load all DLL's while launching AutoCAD 2017 ?
FYI..I use 4 dll's and same no of PackageContents.xml's
Please help me,Thanks
Prakash.T
yes , i need to load all DLL's at startup.i also analyzed like when i keep only one DLL in ApplicationPlugins folder ,it loads immediately.So why the same is not happening when i keep all DLL's in the same location.
