.NET
How to Load CUI File (Ribbon Tabs) And Make Visible via .NET?
5 REPLIES 5
3694 Views, 5 Replies
How do I Load CUI File (Ribbon Tabs) And Make Visible via .NET?
I know how to load a cui file, I know how to make a Ribbon... but how do I load a CUI file and then make the ribbon visible via code?
.NET Code or Refernce to the correct objects and properties would sure help.
5 REPLIES 5
Balaji_Ram
1) To load / unload a CUI file, you may use "acedCmd" using P/Invoke. Here is a sample code :
[DllImport("acad.exe", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedCmd")]
private static extern int acedCmd(System.IntPtr vlist);
ResultBuffer rb = new ResultBuffer();
// RTSTR = 5005
rb.Add(new TypedValue(5005, "FILEDIA"));
rb.Add(new TypedValue(5005, "0"));
acedCmd(rb.UnmanagedObject);
string cuiFileName = cs.CUIFileBaseName;
//CUIUNLOAD
rb.Add(new TypedValue(5005, "_CUIUNLOAD"));
rb.Add(new TypedValue(5005, cuiFileName));
//CUILOAD
rb.Add(new TypedValue(5005, "_CUILOAD"));
//FILEDIA
rb.Add(new TypedValue(5005, "1"));
2)   To make a tab visible, you need to set the "ActiveTab" property of the Ribbon Control
Autodesk.Windows.RibbonControl ribControl = Autodesk.Windows.ComponentManager.Ribbon;
ribControl.ActiveTab = <Set the tab here>
Cheers,
Balaji
Developer Technical Services
Autodesk Developer Network
Balaji
in reply to: Balaji_Ram
Thank you for the response.
I was able to get the cui loading working.
My intent is to load the CUIX file and then enable the Panels & Tabs from the CUIX file.
I'm having a problem enabling them, even when the CUIX file is loaded.
My Loop doesn't find the Ribbon tab when it's not visible in the collection.
When I check the Tab and make it visible... then it's visible in the collection.
I need a little direction here.
 <CommandMethod("listrib")> _
Sub listrib()
        Dim i As Integer
        Dim ribcontrol As Autodesk.Windows.RibbonControl = Autodesk.Windows.ComponentManager.Ribbon
        Dim ribTab As Autodesk.Windows.RibbonTab
        For i = 0 To ribcontrol.Tabs.Count - 1
            With ribcontrol.Tabs
                ed.WriteMessage("Name: " & .Item(i).Name & " ID:" & .Item(i).Id & Environment.NewLine)
                If .Item(i).Name = "SFR Tab" Then
                    .Item(i).IsActive = True
            End With
        Next
    End Sub
Balaji_Ram
I have attached a sample project that loads a cuix file and then sets the tab as active. I have used the same code that you have shown for iterating through the tabs. It works ok for me.
Balaji
I re-installed Autocad yesterday because it was giving me strange errors and the default profile became corrupted.
This morning I tried your Example Solution and it worked seamlessly.
Appreciate the Help. Problem solved.
dcassara
open autocad 2013 and states that CUI files are found. how do retrieve CUIfiles to impport into autocad
”Boost
