How do I Load CUI File (Ribbon Tabs) And Make Visible via .NET?
I know how to load a cui file, I know how to make a Ribbon... but how do I load a CUI file and then make the ribbon visible via code?
.NET Code or Refernce to the correct objects and properties would sure help.
Solved by Balaji_Ram. Go to Solution.
1) To load / unload a CUI file, you may use "acedCmd" using P/Invoke. Here is a sample code :
[DllImport("acad.exe", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedCmd")]
private static extern int acedCmd(System.IntPtr vlist);
ResultBuffer rb = new ResultBuffer();
// RTSTR = 5005
rb.Add(new TypedValue(5005, "FILEDIA"));
rb.Add(new TypedValue(5005, "0"));
acedCmd(rb.UnmanagedObject);
string cuiFileName = cs.CUIFileBaseName;
//CUIUNLOAD
rb.Add(new TypedValue(5005, "_CUIUNLOAD"));
rb.Add(new TypedValue(5005, cuiFileName));
//CUILOAD
rb.Add(new TypedValue(5005, "_CUILOAD"));
//FILEDIA
rb.Add(new TypedValue(5005, "1"));
2) To make a tab visible, you need to set the "ActiveTab" property of the Ribbon Control
Autodesk.Windows.RibbonControl ribControl = Autodesk.Windows.ComponentManager.Ribbon;
ribControl.ActiveTab = <Set the tab here>
Cheers,
Balaji
Developer Technical Services
Autodesk Developer Network
Thank you for the response.
I was able to get the cui loading working.
My intent is to load the CUIX file and then enable the Panels & Tabs from the CUIX file.
I'm having a problem enabling them, even when the CUIX file is loaded.
My Loop doesn't find the Ribbon tab when it's not visible in the collection.
When I check the Tab and make it visible... then it's visible in the collection.
I need a little direction here.
<CommandMethod("listrib")> _ Sub listrib() Dim i As Integer Dim ribcontrol As Autodesk.Windows.RibbonControl = Autodesk.Windows.ComponentManager.Ribbon Dim ribTab As Autodesk.Windows.RibbonTab For i = 0 To ribcontrol.Tabs.Count - 1 With ribcontrol.Tabs ed.WriteMessage("Name: " & .Item(i).Name & " ID:" & .Item(i).Id & Environment.NewLine) If .Item(i).Name = "SFR Tab" Then .Item(i).IsActive = True End If End With Next End Sub
I have attached a sample project that loads a cuix file and then sets the tab as active. I have used the same code that you have shown for iterating through the tabs. It works ok for me.
I re-installed Autocad yesterday because it was giving me strange errors and the default profile became corrupted.
This morning I tried your Example Solution and it worked seamlessly.
Appreciate the Help. Problem solved.
@VB_Autocad_guy wrote:How do I Load CUI File (Ribbon Tabs) And Make Visible via .NET?
open autocad 2013 and states that CUI files are found. how do retrieve CUIfiles to impport into autocad
