Hi,all:
I just make a cad.net program with a simple winform.
when i hide the form or dispose the form, the autocad creen will flesh one time.
i saw the forms in autocad application not flesh when colse or hide them.
Is there any method let the form display silently?
best regards
swaywood
Solved by Balaji_Ram. Go to Solution.
anyone met this?
i know this question is not a cad question at all, it is a c# question, but any one can help me?
best regards
swaywood
sorry, the word 'flesh' i post in this message is 'flash', means '
hi,conormccartney:
thank you for your reply.
i just make one simple sample, which can only select a point.
the following is the code, and attached is the whole solustion file.
when i click the button, the screen will flash
using System; using System.Collections.Generic; using System.Linq; using System.Text; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Runtime; namespace ClassLibrary2 { public class Class1 { [CommandMethod("test")] public void test() { Form1 frm = new Form1(); Application.ShowModalDialog(frm); } } }
using System; using System.Collections.Generic; using System.ComponentModel; using System.Data; using System.Drawing; using System.Linq; using System.Text; using System.Windows.Forms; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Runtime; namespace ClassLibrary2 { public partial class Form1 : Form { Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor; public Form1() { InitializeComponent(); } private void button1_Click(object sender, EventArgs e) { this.Hide(); PromptPointOptions ppo = new PromptPointOptions("\nplease select a point:"); PromptPointResult ppr = ed.GetPoint(ppo); if (ppr.Status == PromptStatus.OK) { this.Show(); label1.Text = ppr.Value.ToString(); } } private void Form1_Load(object sender, EventArgs e) { label1.Text = "load"; } } }
Hi Swaywood,
You can also try the "EditorUserInteraction" :
http://adndevblog.typepad.com/autocad/2012/05/taking-mouse-inputs-from-a-modal-dialog-box.html
Balaji
