.NET
how to know the lisp file was loaded in current doc by c#.net
4 REPLIES 4
swaywood
467 Views, 4 Replies
could anyone tell me how to judge whether the lisp file was loaded in current doc by c#.net?
thks
4 REPLIES 4
fieldguy
in reply to: swaywood
Is it a lisp created by you?  If so, you could set a variable in the lisp routine like USERS1 (string).
swaywood
in reply to: fieldguy
could you give more details?
my lisp file maybe a lisp or vlx
fieldguy
In your lisp you could do something like:
(setvar USERS1 "this lisp is loaded")
Then in your C# code you could use something like:
string checkvar = Application.GetSystemVariable("USERS1")
If USERS1 is empty, or not = "this lisp is loaded", then it's not loaded.
swaywood
thank you for your reply, but i can not change some of the vlx file
”Boost
