.NET
Valued Contributor
RamanSBV
Message 1 of 3 (144 Views)
how to know current drawing is don't have any xref.
144 Views, 2 Replies
08-23-2012 12:00 AM
How to know current drawing is don't have any xref
Raman
Try here
http://www.theswamp.org/index.php?topic=22884.msg275290#msg275290
but long story short :
 Document doc = acadApp.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
// Get the xref graph for the current dbase...
XrefGraph xrefGraph = db.GetHostDwgXrefGraph(true);
if (xrefGraph == null || xrefGraph.IsEmpty || xrefGraph.NumNodes == 1)
ed.WriteMessage("\nNo xrefs found.");
return;
      You may want to loop through BlockTable and check
     all BlockTableRecord on properties:
    IsFromExternalReference or IsFromOverlayReference
    Not tested, just was written in notepad
 [CommandMethod("xrf")]
public static void testXref()
bool whatabout = XrefIncluded();
Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(string.Format("Xref?\t{0}",
whatabout));
public static bool XrefIncluded()
bool include = false;
Document doc = Application.DocumentManager.MdiActiveDocument;
using (Transaction tr = db.TransactionManager.StartTransaction())
BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
foreach (ObjectId id in bt)
BlockTableRecord btr = tr.GetObject(id, OpenMode.ForRead, false) as BlockTableRecord;
// check if Xref
if (btr.IsFromExternalReference || btr.IsFromOverlayReference)
include= true;
break;
tr.Commit();
return include;
Valued Mentor
KerryBrown
Message 2 of 3 (135 Views)
Re: how to know current drawing is don't have any xref.
08-23-2012 02:41 AM in reply to: RamanSBV
Try here
                return;
class keyThumper<T> : Lazy<T>;      another  Swamper
Hallex
Message 3 of 3 (114 Views)
08-23-2012 06:10 AM in reply to: RamanSBV
whatabout));
             // check if Xref
     include= true;
                  break;
            tr.Commit();
           return include;
