.NET
how to know current drawing is don't have any xref.
2 REPLIES 2
RamanSBV
434 Views, 2 Replies
How to know current drawing is don't have any xref
Raman
2 REPLIES 2
kdub_nz
in reply to: RamanSBV
Try here
http://www.theswamp.org/index.php?topic=22884.msg275290#msg275290
but long story short :
            Document doc = acadApp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            // Get the xref graph for the current dbase...
            XrefGraph xrefGraph = db.GetHostDwgXrefGraph(true);
            if (xrefGraph == null || xrefGraph.IsEmpty || xrefGraph.NumNodes == 1)
                ed.WriteMessage("\nNo xrefs found.");
                return;
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Hallex
      You may want to loop through BlockTable and check
     all BlockTableRecord on properties:
    IsFromExternalReference or IsFromOverlayReference
    Not tested, just was written in notepad
        [CommandMethod("xrf")]
    public static void testXref()
         bool whatabout = XrefIncluded();
        Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(string.Format("Xref?\t{0}",
whatabout));
    public static bool XrefIncluded()
          bool include = false;
         Document doc = Application.DocumentManager.MdiActiveDocument;
                   using (Transaction tr = db.TransactionManager.StartTransaction())
          BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
          foreach (ObjectId id in bt)
             BlockTableRecord btr = tr.GetObject(id, OpenMode.ForRead, false) as BlockTableRecord;
             // check if Xref
         if (btr.IsFromExternalReference || btr.IsFromOverlayReference)
     include= true;
                  break;
            tr.Commit();
           return include;
”Boost
