.NET
.NET
Active Member
0 Kudos
Post 1 of 6
How to jig a Spline (fit points) using AutoCAD 2013 .NET API?
863 Views, 5 Replies
08-20-2012 03:35 AM
How can I draw Spline with fit points in AutoCAD 2013 .NET API using my own jig?
Here is a sample code that might help in getting started with jigging of spline. It is a modified version of the code from this blog post dealing with polyline jigging.
http://through-the-interface.typepad.com/through_the_interface/2010/12/jigging-an-autocad-polyline-with-arc-segments-using-net.html
Here is the code :
using System;
using System.Windows.Forms;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
[assembly: CommandClass(typeof(SplineJig.SplineJigCmds))]
namespace SplineJig
public class SplineDrawJig : DrawJig
// members
private Point3d _point;
private Point3dCollection _points = new Point3dCollection();
public Point3dCollection Coordinates
get
return _points;
public SplineDrawJig()
public void DoIt()
Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
PromptResult jigRes = null;
do
jigRes = ed.Drag(this);
if (jigRes.Status == PromptStatus.OK)
_points.Add(_point);
else if (jigRes.Status == PromptStatus.None)
break;
while (jigRes.Status == PromptStatus.OK);
protected override Autodesk.AutoCAD.EditorInput.SamplerStatus
Sampler(Autodesk.AutoCAD.EditorInput.JigPrompts prompts)
JigPromptPointOptions jigOpts = new JigPromptPointOptions();
jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates | UserInputControls.NullResponseAccepted);
jigOpts.Message = "Select fit point: ";
PromptPointResult jigRes = prompts.AcquirePoint(jigOpts);
Point3d pt = jigRes.Value;
if (pt == _point)
return SamplerStatus.NoChange;
_point = pt;
return SamplerStatus.OK;
return SamplerStatus.Cancel;
protected override bool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.WorldDraw draw)
if (_points.Count == 0)
return true;
Point3dCollection vertices = new Point3dCollection();
foreach (Point3d point in _points)
vertices.Add(point);
vertices.Add(_point);
int totalVertices = vertices.Count;
if(totalVertices >= 2)
Line chordLine = new Line(vertices[totalVertices - 1], vertices[totalVertices-2]);
draw.Geometry.Draw(chordLine);
Spline spline = new Spline(vertices, KnotParameterizationEnum.Chord, 3, 0.0);
draw.Geometry.Draw(spline);
return true;
public class SplineJigCmds
public SplineJigCmds() { }
[CommandMethod("SplineJig")]
static public void SplineJig()
try
Database db = ed.Document.Database;
SplineDrawJig splineJig = new SplineDrawJig();
splineJig.DoIt();
// order of the curve can be between 2 and 26
int order = 6;
// determines extent of interpolation through all the points
double fitTolerance = .5;
Spline spline = new Spline(splineJig.Coordinates, KnotParameterizationEnum.Chord, 3, 0.0);
using (Transaction tr = db.TransactionManager.StartTransaction())
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
btr.AppendEntity(spline);
tr.AddNewlyCreatedDBObject(spline, true);
tr.Commit();
catch (System.Exception ex)
MessageBox.Show(ex.Message, "Exception", MessageBoxButtons.OK, MessageBoxIcon.Error);
 Hope this helps.
ADN Support Specialist
100 Kudos
Post 2 of 6
Re: How to jig a Spline (fit points) using AutoCAD 2013 .NET API?
08-27-2012 10:02 AM in reply to: JoseVicario
http://through-the-interface.typepad.com/through_the_interface/2010/12/jigging-an-autocad-polyline-w...
Here is the code :
using System;
namespace SplineJig
		// members
			get
				return _points;
		public void DoIt()
			do
					break;
			if (pt == _point)
			_point = pt;
				return true;
			return true;
			try
				splineJig.DoIt();
                int order = 6;
					tr.Commit();
 Hope this helps.
Balaji
Developer Technical Services
Autodesk Developer Network
Active Member
0 Kudos
Post 3 of 6
08-28-2012 12:40 AM in reply to: Balaji_Ram
Thank You for answer. Perfect solution!
4 Kudos
Post 4 of 6
05-20-2013 02:58 PM in reply to: JoseVicario
I'd like to add an rotated entity to the ends of the spline.
The Spline.StartFitTangent is giving a result of (0,0,0)
Is there another way of getting the angle of the start and endpoints?
Distinguished Mentor
91 Kudos
Post 5 of 6
05-20-2013 04:30 PM in reply to: SRSDS
you can obtain the tangent angle from the first derivative of the curve with: MySpline.GetFirstDerivative(AtSomePoint), check the docs for others method that the curve class have.
Gaston Nunez
4 Kudos
Post 6 of 6
05-21-2013 08:02 AM in reply to: gasty1001
Thanks Gaston!
