How can I draw Spline with fit points in AutoCAD 2013 .NET API using my own jig?
Solved by Balaji_Ram. Go to Solution.
Here is a sample code that might help in getting started with jigging of spline. It is a modified version of the code from this blog post dealing with polyline jigging.
Here is the code :
using System; using System.Windows.Forms; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; [assembly: CommandClass(typeof(SplineJig.SplineJigCmds))] namespace SplineJig { public class SplineDrawJig : DrawJig { // members private Point3d _point; private Point3dCollection _points = new Point3dCollection(); public Point3dCollection Coordinates { get { return _points; } } public SplineDrawJig() { } public void DoIt() { Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor; PromptResult jigRes = null; do { jigRes = ed.Drag(this); if (jigRes.Status == PromptStatus.OK) { _points.Add(_point); } else if (jigRes.Status == PromptStatus.None) { break; } } while (jigRes.Status == PromptStatus.OK); } protected override Autodesk.AutoCAD.EditorInput.SamplerStatus Sampler(Autodesk.AutoCAD.EditorInput.JigPrompts prompts) { JigPromptPointOptions jigOpts = new JigPromptPointOptions(); jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates | UserInputControls.NullResponseAccepted); jigOpts.Message = "Select fit point: "; PromptPointResult jigRes = prompts.AcquirePoint(jigOpts); Point3d pt = jigRes.Value; if (pt == _point) { return SamplerStatus.NoChange; } _point = pt; if (jigRes.Status == PromptStatus.OK) { return SamplerStatus.OK; } return SamplerStatus.Cancel; } protected override bool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.WorldDraw draw) { if (_points.Count == 0) { return true; } Point3dCollection vertices = new Point3dCollection(); foreach (Point3d point in _points) { vertices.Add(point); } vertices.Add(_point); int totalVertices = vertices.Count; if(totalVertices >= 2) { Line chordLine = new Line(vertices[totalVertices - 1], vertices[totalVertices-2]); draw.Geometry.Draw(chordLine); } Spline spline = new Spline(vertices, KnotParameterizationEnum.Chord, 3, 0.0); draw.Geometry.Draw(spline); return true; } } public class SplineJigCmds { public SplineJigCmds() { } [CommandMethod("SplineJig")] static public void SplineJig() { try { Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor; Database db = ed.Document.Database; SplineDrawJig splineJig = new SplineDrawJig(); splineJig.DoIt(); // order of the curve can be between 2 and 26 int order = 6; // determines extent of interpolation through all the points double fitTolerance = .5; Spline spline = new Spline(splineJig.Coordinates, KnotParameterizationEnum.Chord, 3, 0.0); using (Transaction tr = db.TransactionManager.StartTransaction()) { BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite); btr.AppendEntity(spline); tr.AddNewlyCreatedDBObject(spline, true); tr.Commit(); } } catch (System.Exception ex) { MessageBox.Show(ex.Message, "Exception", MessageBoxButtons.OK, MessageBoxIcon.Error); } } } }
Hope this helps.
I'd like to add an rotated entity to the ends of the spline.
The Spline.StartFitTangent is giving a result of (0,0,0)
Is there another way of getting the angle of the start and endpoints?
you can obtain the tangent angle from the first derivative of the curve with: MySpline.GetFirstDerivative(AtSomePoint), check the docs for others method that the curve class have.
Gaston Nunez
