incidentally, the answer is to use the GetContainersmethod of the PromptNestedEntityResult return.
It will have the blocks above the nested item.
James Maeding
|>I've gotten som good help on this from theSwamp, I'd like to hear what you guys have to say on this too.
|>lets say I want to list the layer name of each nesting level of an object.
|>So if the object is a line, in a block, in an xref, how do I get the blockreference entity from the line?
|>I see how to use OwnerID to get the blockTableRecord, but not the blockreference...
|>How would I tell if the level above any given level is another blockreference, or an xref or modelspace or paperspace?
|>thanks
|>James Maeding
|>Civil Engineer and Programmer
|>jmaeding - athunsaker - com
James Maeding
