I know I can use the following...
... Polyline3d pl3d = acEnt as Polyline3d; foreach (ObjectId id in pl3d) { PolylineVertex3d plv3d = tr.GetObject(id, OpenMode.ForRead) as PolylineVertex3d; Point3d p3d = plv3d.Position; ... }
But I need to work with "for" loop.
It seems "pl3d[i]" does not work.
Is there other ways to iterate through Polyline3d vertices?
Solved by Alexander.Rivilis. Go to Solution.
Hmm....
Looks like the following will do the job.
Polyline3d pline3d = ent as Polyline3d; for (double i = 0; i < pline3d.EndParam; i = i + 1 ) { Point3d p3d = pline3d.GetPointAtParameter(i); }
Is that correct?
using System; using System.Linq; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.EditorInput; [assembly: CommandClass(typeof(Rivilis.CurveUtils))] namespace Rivilis { public class CurveUtils { [CommandMethod("ListPoly3D", CommandFlags.Modal)] public static void ListPoly3D() { Document doc = Application.DocumentManager.MdiActiveDocument; Editor ed = doc.Editor; PromptEntityOptions prCurv = new PromptEntityOptions("\nSelect Polyline3d: "); prCurv.SetRejectMessage("not a Polyline3d"); prCurv.AddAllowedClass(typeof(Polyline3d), false); PromptEntityResult resCurv = ed.GetEntity(prCurv); if (resCurv.Status != PromptStatus.OK) return; using (Transaction tr = doc.TransactionManager.StartTransaction()) { Polyline3d pl3d = tr.GetObject(resCurv.ObjectId, OpenMode.ForRead) as Polyline3d; ObjectId[] verts = pl3d.Cast<ObjectId>().ToArray(); ed.WriteMessage("\nNumber of vertexes: {0}", verts.Length); for (int i = 0; i < verts.Length; i++) { PolylineVertex3d vt = tr.GetObject(verts[i], OpenMode.ForRead) as PolylineVertex3d; if (vt != null) { ed.WriteMessage("\n[{0}] = {1}", i, vt.Position.ToString()); } } tr.Commit(); } } } }
Facebook | Twitter | LinkedIn
@Anonymous wrote:
Is that correct?
It is look like you skip last vertex...
