.NET
How to insert blockreference not in drawing
10 REPLIES 10
Message 1 of 11
872 Views, 10 Replies
how can i insert a blockreference when the block is not in the drawing
but in one of the supportpath?
Roland
10 REPLIES 10
Message 2 of 11
netcai
you can use objectdbx
Message 3 of 11
Is it not possible to do it with the Managed Wrapper Classes in C#?
Roland
Message 4 of 11
It is possible. In fact, it is also possible using the COM API. I'd
recommend that you use the COM API method InsertBlock and specify the file
name. You can do this from C#.
If you use the .NET API directly then you must do a find file on the file
name (HostApplicationServices.FindFile). Then open the drawing using
Database.ReadDwgFile and then finally insert it using Database.Insert. The
COM API does the exact same thing in hte InsertBlock method.
Albert
"Roland Feletic" wrote in message
news:4892457@discussion.autodesk.com...
Roland
Message 5 of 11
Thank you, Albert.
I will have a look at this two ways.
First is a little bit easier, second is more interresting 😉
Roland
Message 6 of 11
netcai
Albert,
I use .net api method ,but failed.
HostApplicationServices doesn't has FindFile property, I can read file, but I don't know how to use Database.Insert method,could you show some examples in detail.
Message 7 of 11
I'm not sure why you can't find FindFile. Here's an example anyway:
public class Testinsert
[CommandMethod("testinsert")]
static public void DoIt()
Document doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
PromptResult res = ed.GetString("Give me a file to insert");
if (res.Status != PromptStatus.OK)
return;
string fname = res.StringResult;
if (!File.Exists(fname))
fname =
HostApplicationServices.Current.FindFile(fname,doc.Database,FindFileHint.Default);
using (Database db = new Database(false,false))
//read drawing
db.ReadDwgFile(fname,FileShare.Read,true,null);
using (Transaction t =
doc.TransactionManager.StartTransaction())
//insert it as a new block
ObjectId idBTR = doc.Database.Insert("test",db,false);
//create a ref to the block
BlockTable bt =
(BlockTable)t.GetObject(doc.Database.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr =
(BlockTableRecord)t.GetObject(bt[BlockTableRecord.ModelSpace],
OpenMode.ForWrite);
using (BlockReference bref = new
BlockReference(Point3d.Origin,idBTR))
btr.AppendEntity(bref);
t.AddNewlyCreatedDBObject(bref, true);
t.Commit();
wrote in message news:4894592@discussion.autodesk.com...
Albert,
in detail.
Message 8 of 11
netcai
I run your code ,but a error appear.
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> Autodesk.AutoCAD.Runtime.Exception: eSelfReference
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
//Editor ed = doc.Editor;
//PromptResult res = ed.GetString("Give me a file to insert");
//if (res.Status != PromptStatus.OK)
// return;
//string fname = res.StringResult;
string fname = @"E:\My Documents\临时\plan-NA.dwg";
if ( ! File.Exists(fname))
fname = HostApplicationServices.Current.FindFile(fname, doc.Database, FindFileHint.Default);
using (Database db = new Database(false, false))
//read drawing
db.ReadDwgFile(fname, FileShare.Read, true, null);
ObjectId idBTR = doc.Database.Insert("N_spot", db, false);
BlockTable bt = (BlockTable)t.GetObject(doc.Database.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
using (BlockReference bref = new BlockReference(Point3d.Origin, idBTR))
t.Commit();
Message 9 of 11
Make sure that you are not inserting the drawing into itself and that you
don't already have a block called "N_spot". The code I posted works well if
you run it on a newly created drawing.
ALbert
wrote in message news:4895903@discussion.autodesk.com...
eSelfReference
Document doc =
// return;
string fname = @"E:\My Documents\??\plan-NA.dwg";
//read drawing
false);
BlockTable bt =
OpenMode.ForWrite);
t.Commit();
Message 10 of 11
Hallo Albert,
thank you for your code, hope that i have a little more time after my
holiday.
Roland
Message 11 of 11
netcai
thanks ,I se.
but how to copy a block from a unopened file to current document. I tried use
ObjectId idBTR = doc.Database.Insert( sourceBlockname,destinationBlockName, db, false), but failed.A fatal error accured,
”Boost
