Hi, everyone!
I try to used "SendStringToExecute("._insert ", true, false, false)", it does well except that I don't need the insert block form showing. I know the block's name exactly, and I'd like to insert the block directly with the block's preview shape following the mouse cursor.
Solved by viper_007. Go to Solution.
Solved by cadprogramming. Go to Solution.
Instead of "._Insert" try "-INSERT".
The dash in front of insert will cause the command to be run from command line instead of dialog.
You will need to feed the command the right arguments so try it at command line first.
