.NET
.NET
0 Kudos
Post 1 of 6
How to Initialize AcadEntity array Object with NULL value in C#.Net ?
546 Views, 5 Replies
08-06-2012 10:39 PM
Hi all,
I would like to know how to initialize the AcadEntity type of array variable with an ACADEntity object
My code is as below,
AcadEntity[] SelEntList;
AcadEntity MyEnt;
SelEntList[0] = MyEnt;
I am getting an error as below
Use of unassigned local variable 'MyEnt'
In case of a string array, I would be doing MyStr[0] = "" and it works but how to do this w.r.t. AcadEntity array ?
You have to intialize your variables after (or while) you declare them.
AcadEntity[] SelEntList = new AcadEntity[arrayLength]; // you have to specify the array size when initilzing it.
AcadEntity MyEnt = null;
Have a look at the System.Collections.Generic.List<T> which has some intersting features the array don't have.
254 Kudos
Post 2 of 6
Re : How to Initialize AcadEntity array Object with NULL value in C#.Net ?
08-06-2012 11:43 PM in reply to: CodeBug
Gilles Chanteau
171 Kudos
Post 3 of 6
Re: How to Initialize AcadEntity array Object with NULL value in C#.Net ?
08-07-2012 03:55 AM in reply to: CodeBug
Try this code that completely based on docs example^
     static Point2d PolarPoints(Point2d pPt, double dAng, double dDist)
            return new Point2d(pPt.X + dDist * Math.Cos(dAng),
                               pPt.Y + dDist * Math.Sin(dAng));
        // create grid using rectangular array
        [CommandMethod("sqv")]
        public static void TestFillSquares()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            PromptPointOptions ppo = new PromptPointOptions("\nPick a lower left corner: ");
            PromptPointResult res = ed.GetPoint(ppo);
            if (res.Status != PromptStatus.OK) return;
            Point3d p1 = res.Value;
            PromptCornerOptions pko = new PromptCornerOptions("\nPick opposite corner: ", p1);
            res = ed.GetCorner(pko);
            Point3d p2 = res.Value;
            //start a transaction
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                // create polyline to make the shape
                Polyline poly = new Polyline(4);
                poly.AddVertexAt(0, new Point2d(p1.X, p1.Y), 0, 0, 0);
                poly.AddVertexAt(1, new Point2d(p2.X, p1.Y), 0, 0, 0);
                poly.AddVertexAt(2, new Point2d(p2.X, p2.Y), 0, 0, 0);
                poly.AddVertexAt(3, new Point2d(p1.X, p2.Y), 0, 0, 0);
                poly.Closed = true;
                btr.AppendEntity(poly);
                tr.AddNewlyCreatedDBObject(poly, true);
                double leg = Math.Abs(p2.X - p1.X);
                double wid = Math.Abs(p2.Y - p1.Y);
                // Create a rectangular array with 5 rows and 8 columns
                int nRows = 5;
                int nColumns = 8;
                double disrows = leg / nColumns;
                double discols = wid / nRows;
                Polyline npoly = new Polyline(4);
                npoly.AddVertexAt(0, new Point2d(p1.X, p1.Y), 0, 0, 0);
                npoly.AddVertexAt(1, new Point2d(p1.X + disrows, p1.Y), 0, 0, 0);
                npoly.AddVertexAt(2, new Point2d(p1.X + disrows, p1.Y + discols), 0, 0, 0);
                npoly.AddVertexAt(3, new Point2d(p1.X, p1.Y + discols), 0, 0, 0);
                npoly.Closed = true;
                npoly.ColorIndex = 1;
                btr.AppendEntity(npoly);
                tr.AddNewlyCreatedDBObject(npoly, true);
                // Set the row and column offsets along with the base array angle
                double dRowOffset = discols;
                double dColumnOffset = disrows;
                double dArrayAng = 0;
                // Get the angle from X for the current UCS
                Matrix3d curUCSMatrix = ed.CurrentUserCoordinateSystem;
                CoordinateSystem3d curUCS = curUCSMatrix.CoordinateSystem3d;
                Vector2d acVec2dAng = new Vector2d(curUCS.Xaxis.X,
                                                   curUCS.Xaxis.Y);
                // If the UCS is rotated, adjust the array angle accordingly
                dArrayAng = dArrayAng + acVec2dAng.Angle;
                // Use the upper-left corner of the objects extents for the array base point
                Extents3d acExts = npoly.Bounds.GetValueOrDefault();
                Point2d acPt2dArrayBase = new Point2d(acExts.MinPoint.X,
                                                      acExts.MaxPoint.Y);
                // Track the objects created for each column
                DBObjectCollection acDBObjCollCols = new DBObjectCollection();
                acDBObjCollCols.Add(npoly);
                // Create the number of objects for the first column
                int nColumnsCount = 1;
                while (nColumns > nColumnsCount)
                    Entity acEntClone = npoly.Clone() as Entity;
                    acDBObjCollCols.Add(acEntClone);
                    // Caclucate the new point for the copied object (move)
                    Point2d acPt2dTo = PolarPoints(acPt2dArrayBase,
                                                   dArrayAng,
                                                   dColumnOffset * nColumnsCount);
                    Vector2d acVec2d = acPt2dArrayBase.GetVectorTo(acPt2dTo);
                    Vector3d acVec3d = new Vector3d(acVec2d.X, acVec2d.Y, 0);
                    acEntClone.TransformBy(Matrix3d.Displacement(acVec3d));
                    btr.AppendEntity(acEntClone);
                    tr.AddNewlyCreatedDBObject(acEntClone, true);
                    nColumnsCount = nColumnsCount + 1;
                // Set a value in radians for 90 degrees
                double dAng = Math.PI / 2;
                // Track the objects created for each row and column
                DBObjectCollection acDBObjCollLvls = new DBObjectCollection();
                foreach (DBObject acObj in acDBObjCollCols)
                    acDBObjCollLvls.Add(acObj);
                // Create the number of objects for each row
                foreach (Entity acEnt in acDBObjCollCols)
                    int nRowsCount = 1;
                    while (nRows > nRowsCount)
                        Entity acEntClone = acEnt.Clone() as Entity;
                        acDBObjCollLvls.Add(acEntClone);
                                                       dArrayAng + dAng,
                                                       dRowOffset * nRowsCount);
                        nRowsCount = nRowsCount + 1;
                tr.Commit();
~'J'~
0 Kudos
Post 4 of 6
08-07-2012 04:02 AM in reply to: _gile
Thanks _gile! Thats the missing !
0 Kudos
Post 5 of 6
08-07-2012 04:03 AM in reply to: Hallex
Thanks Hallex !! Refered your code in my attempt..
171 Kudos
Post 6 of 6
08-07-2012 04:15 AM in reply to: CodeBug
You're welcome
Happy coding :smileyhappy:
~'J'~
