.NET
How to Import and delete workspaces?
3 REPLIES 3
mobj
1593 Views, 3 Replies
I've tried searching the ObjectARX dokumentation and this forum, but can't find any methods to import/transfer a workspace from one CUIx to the Mail CUIx. Also I need a method to delete an existing workspace in the main CUIx.
Can someone point me in the right direction?
Morten Bastue Jacobsen
Rambøll Danmark A/S
www.ramboll.dk
3 REPLIES 3
techsoft3d
in reply to: mobj
Check out this thread, there's a sample project attached to Wayne Brill's post (CUISAMP_2010.zip) that iterates workspaces, and I think there's also sample code for add and removal of workspaces.
http://forums.autodesk.com/t5/NET/Creating-new-customized-menu-and-toolbar-in-Autocad-2010-using/td-...
Cheers,
Paavo
Paavo is correct, this link will show you how to work with Workspaces and CUI elements.
This API is only available in .Net.
Philippe.
[CommandMethod("CloneWorkSpace")]
public void CloneWorkSpace()
    try
        string sourceCuiFileName = @"C:\TEST.CUIX";
        if (!System.IO.File.Exists(sourceCuiFileName))
            return;
        string curCuiFileName = Application.GetSystemVariable("MENUNAME").ToString() + ".cuix";
        CustomizationSection curCui = new CustomizationSection(curCuiFileName);
        CustomizationSection sourceCui = new CustomizationSection(sourceCuiFileName);
        string workspaceName = "Acme Workspace";
        WorkspaceCollection curWorkspaces = curCui.Workspaces;
        int curWsIdx = curWorkspaces.IndexOfWorkspaceName(workspaceName);
        // Acme Workspace already exists, so just return
        // cloning overwrites the existing Workspace
        if (curWsIdx != -1)
            return;
        Workspace newWs = sourceCui.getWorkspace(workspaceName);
        ContainerCloneAction containerClnAction = new ContainerCloneAction();
        Workspace ws = curWorkspaces[0];
        curWorkspaces.Clone(newWs, ws, ref containerClnAction);
        if (curCui.IsModified)
            curCui.Save();
    catch (Autodesk.AutoCAD.Runtime.Exception e)
        Application.ShowAlertDialog("AutoCAD exception:\n" + e.Message);
        return;
// Command: remws
// This command removes a workspace. The name of the workspace to remove is
// obtained from the command line.
[CommandMethod("remws")]
public void remws()
    String wsName;
    PromptResult prs = ed.GetString("Enter name of workspace to remove: ");
    if (PromptStatus.OK == prs.Status)
        wsName = prs.StringResult;
        // If the workspace exist
        if (-1 != cs.Workspaces.IndexOfWorkspaceName(wsName))
            cs.deleteWorkspace(wsName); // Remove the workspace
            saveCui(); // Save and reload the CUI file
        else
            ed.WriteMessage("No workspace exists with this name");
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
mobj
in reply to: philippe.leefsma
Thanks, this looks very promising. 🙂
Rambøll Danmark A/S
www.ramboll.dk
”Boost
