Show only
Search instead for
how to implement IPropertySource to add per-instance property?
My code is based on Kean's article "Exposing AutoCAD's Properties Palette functionality to .NET".I expand it,wrapped IPropertySource,OPMPerInstancePropertyExtension,OPMPerInstancePropertyExtensionFactory,OPMPerInstancePropertySources in C#.All thing is right except IPropertySource.
Here is the IPropertySource interface source code:
{code}
interface DECLSPEC_UUID("61D0A8E3-C792-4956-8E96-594315B95902")
IPropertySource : public IUnknown
BEGIN_INTERFACE
// *** IUnknown methods ****
// Call this when your property changes
STDMETHOD(get_Name)(THIS_ /*[out, retval]*/BSTR* pName) PURE;
// Call to get the current selection set OPM is working with, returns a SAFEARRAY
// of LONGs representing the objectIDs of the set, be sure to call VariantClear to cleanup
STDMETHOD(GetProperties)(THIS_ /*[in]*/IUnknown* pObject, /*[out, retval]*/VARIANT *pPropertyArray) PURE;
{code}
Here is the document of GetProperties
The pProperties array contains pointers to IDynamicProperty instances that describe additional properties of the object. If the property source object does not generate any dynamic properties, pProperties can be VT_EMPTY or an empty array.
I declared like this
{code}
[InteropServices::Guid("61D0A8E3-C792-4956-8E96-594315B95902")]
[InteropServices::InterfaceTypeAttribute(InteropServices::ComInterfaceType::InterfaceIsIUnknown)]
[InteropServices::ComVisible(true)]
public interface class IPropertySource
//[return: MarshalAs(UnmanagedType::BStr)]
String^ get_Name();
//[return: MarshalAs(UnmanagedType::SafeArray, SafeArraySubType=VarEnum::VT_UNKNOWN)]
array
wrote in message news:6293566@discussion.autodesk.com...
{code}
BEGIN_INTERFACE
SAFEARRAY
{code}
empty array.
{code}
String^ get_Name();
array
