.NET
How to implement Drop-down list (based on IDynamicEnumProperty) in OPM?
3 REPLIES 3
markus.keller
1191 Views, 3 Replies
Hi!
Is there somone who can explain/show a sample of how a custom drop-down list in OPM can be implemented? Based on some articels by Kean Walmsley, I have successfully implemented categorized properties in the OPM using a .NET wrapper and C#. I have a class imlementing the members of the IDynamicEnumProperty, ICategorizeProperties and IDynamicProperty2 interfaces (based on ObjectARX 2013).
However, I do not really understand how to code custom drop-down list using .NET wrapper and OPM. I am using AutoCAD 2013 and 2014. I have read a lot of posts regarding OPM but there was no helpful information in regards to create custom drop-down lists. I will greatly appreciate any help showing how to achieve that or giving a link to more details.
Markus
3 REPLIES 3
Balaji_Ram
in reply to: markus.keller
Hi Markus,
Sorry for the delay.
I have attached a sample project that my colleague Philippe Leefsma had created some time back to demonstrate this.
Hope this helps.
Balaji
Developer Technical Services
Autodesk Developer Network
markus.keller
in reply to: Balaji_Ram
Hi Balaji,
Thank you for the response and the example code which works perfect in my case. Cool stuff. I had to tweak the C++ project to make it compile in my environment, but it finally worked well for me.
You also solved another issue by showing how to use a CustomProperty constructor to initialize field data overriding some of the implemented interface members in the DynamicProperty class. This was actually a minor issue I was still working on ... so, thank you for solving this also 😉
Markus
Markus
Balaji_Ram
Hi Markus,
Glad to hear that the sample project was helpful.
I have communicated your appreciation to Philippe who is author of that sample project.
Balaji
”Boost
