.NET
.NET
Member
0 Kudos
Post 1 of 3
How To Implement AutoCAD Color Chooser In External Application
104 Views, 2 Replies
05-01-2014 06:48 AM
Goal
I want to be able to access AutoCAD's Color chooser from an external application. This means that I will not be using AutoCAD to make the color chooser dialog popup. Instead, I will be using a VB.Net application to manage these colors.
AutoCAD Color chooser
Current Situation
As for now, I have no idea where to start. Do I need to import a specific library to make this work? Is it even possible to do this without AutoCAD running?
504 Kudos
Post 2 of 3
Re: How To Implement AutoCAD Color Chooser In External Application
05-01-2014 08:00 AM in reply to: Alex_AMF
If you are going to be doing this without AutoCAD, then you need to roll your own.  There might be an RGB - ACI translation function out there for display purposes, otherwise you could just build your own map.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Valued Mentor
67 Kudos
Post 3 of 3
05-01-2014 11:31 AM in reply to: Alex_AMF
