'This problem' is that you don't have the prerequisites, which is a reasonable
understanding of the programming language, and that is not applicable to this
forum.
I told you to set the 'Default' property of the KeywordCollection object
(accessed via the Keywords property of the PromptKeywordOptions object), and you
couldn't manage to figure that out.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6341066@discussion.autodesk.com...
It's a fairly common event in AutoCAD. Less common without a control to feed the
KeyPress or Key down event handler.
I don't know .NET very well yet but this problem is still very applicable to
this forum.
