.NET
How to get this point
7 REPLIES 7
Message 1 of 8
876 Views, 7 Replies
Please see the picture.
Closet point? No
Intersection point? No...
This point is a special point, just corner of the PolyLine.
I plan to only allow the user to select the red line, then the program loops through all polylines near the red line, and then find that point
Is there someone can help me ? very Thanks
7 REPLIES 7
Message 2 of 8
_gile
If I don't misunderstand, in the Point3dCollection filled with the IntersectWith() method, look for the closest closest to the line EndPoint one.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
in reply to: _gile
   Ah, It’s right, find closet one from the intersection point collection, the one will be the point I want.
   But I found a weird problem, Once I use IntersectWith method, it will find the intersection point with the company's 64 computer, but with my family 32 laptop will throw MissingMethodException.
   How do I solve this problem?
Message 4 of 8
   Ah, the exception I have solved, because I reference acdbmgd.dll and acmgd.dll from AutoCAD directly,
   Now I reference AcMgd and AcDbMgd from ObjectARX_2010_Win_64_and_32Bit \inc-win32, then I can find the intersection with my family 32 laptop
Message 5 of 8
Hallex
Another way if your axis lines starts from circle center:
        [CommandMethod("L22", CommandFlags.UsePickSet)]
        public static void TestCutAxisLines()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = HostApplicationServices.WorkingDatabase;
            Editor ed = doc.Editor;
            Entity ent;
             try
            PromptSelectionOptions pso = new PromptSelectionOptions();
            pso.MessageForRemoval = "\nNot a line objects, exit.";
            pso.MessageForAdding = "\nSelect axis lines : ";
            pso.RejectObjectsOnLockedLayers = true;
            SelectionFilter lnFilter = new SelectionFilter(new TypedValue[] { new TypedValue(0, "line") });
            PromptSelectionResult res = ed.GetSelection(pso, lnFilter);
            if (res.Status != PromptStatus.OK) return;
            SelectionSet sset = res.Value;
            if (sset.Count == 0) return;
            ed.WriteMessage("\nSelected objects:\t{0}\n", sset.Count);
            pso.MessageForRemoval = "\nNot a circle object, exit.";
            pso.MessageForAdding = "\nSelect a single circle : ";
            pso.RejectObjectsOnLockedLayers = false;
            pso.SinglePickInSpace = false;//might be true
            pso.PrepareOptionalDetails = true;
            SelectionFilter crFilter = new SelectionFilter(new TypedValue[] { new TypedValue(0, "circle") });
            PromptSelectionResult cres = ed.GetSelection(pso, crFilter);
            if (cres.Status != PromptStatus.OK) return;
            ed.WriteMessage("\nSelected objects:\t{0}\n", cres.Value.Count);
            ObjectId scId = cres.Value.GetObjectIds()[0];
            pso.MessageForAdding = "\nSelect vertical  line : ";
            pso.SingleOnly = true;
            ObjectId lnId = res.Value.GetObjectIds()[0];
            ed.WriteMessage("\nSelected objects:\t{0}\n", res.Value.Count);
            Vector3d vec = new Vector3d();
            using (Transaction tr = doc.TransactionManager.StartTransaction())
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    Entity lnEnt = (Entity)tr.GetObject(lnId, OpenMode.ForRead);
                    Line vline = new Line();
                    if (lnEnt is Line)
                         vline = lnEnt as Line;
                    Entity crEnt = (Entity)tr.GetObject(scId, OpenMode.ForRead);
                    if (crEnt is Circle)
                        Circle scircle = crEnt as Circle;
                        Point3d dim = vline.GetClosestPointTo(scircle.Center, false);
                         vec = scircle.Center.GetVectorTo(dim);
                    foreach (SelectedObject sobj in sset)
                        if (!sobj.ObjectId.IsValid) continue;
                        ent = (Entity)tr.GetObject(sobj.ObjectId, OpenMode.ForWrite);
                        Line ln = new Line();
                        if (ent is Line)
                            ln = ent as Line;
                            Point3d p1 = ln.StartPoint; Point3d p2 = ln.EndPoint;
                            Point3dCollection pts = new Point3dCollection() { p1, p2 };
                            cres = ed.SelectFence(pts, crFilter);
                            SelectionSet single = cres.Value;
                             if (single.Count == 0) return;
                            Entity cent = (Entity)tr.GetObject(single.GetObjectIds()[0], OpenMode.ForRead);
                            Circle circ = cent as Circle;
                            Point3d cp = circ.Center;
                            Point3d machpt = new Point3d();
                            machpt = p1.DistanceTo(cp) < 0.0001 ? p1 : p2;
                            if (machpt.IsEqualTo(p1, new Tolerance(0.0001, 0.0001)))
                                ed.WriteMessage("\n\tPoint = P1");
                                machpt = machpt.Subtract(vec.MultiplyBy(-1));
                                ln.StartPoint = machpt;
                            else
                                ed.WriteMessage("\n\tPoint = P2");
                                machpt = machpt.Add(vec);
                                ln.EndPoint = machpt;
                           // ln.RecordGraphicsModified(true);//optional
                            // do rest work with object here
                    tr.Commit();
                catch (System.Exception ex)
                    ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
                finally
                // do nothing or display an ending message
                Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage
                    ("\n\t---\tEnd of command L22 is reached.  \t---\n");
Message 6 of 8
in reply to: Hallex
   Oh, This problem has been solved, the approach I take is find the nearest point from the intersection collection, but still very grateful for your help
Message 7 of 8
Hallex
Good for you,
Cheers
Message 8 of 8
in reply to: Hallex
Maybe you can see my new topic about toolbar, I did not know how to solve that problem, little headache, please Smiley Embarassed
”Boost
