.NET
how to get the true name of an anonymous block?
14 REPLIES 14
Message 1 of 15
swaywood
3883 Views, 14 Replies
now i can get the anonymous blockname like 'uxxx', but i want to know the original block name before the insert changed to an anonymous block.
ps,the block is not a dynamic block.
Tags (1)
14 REPLIES 14
Message 2 of 15
in reply to: swaywood
You can use BlockReference.DynamicBlockTableRecord to open the BlockTableRecord and get its name property but if it is not dynamic not sure how that will help.
Message 3 of 15
swaywood
thack you for your reply,i will try as a dynamic block, but maybe it dosnt work.
Message 4 of 15
hgasty1001
This has been asked before, something like this should help:
Public Shared Function GetEffectiveName(ByVal blkref As BlockReference, ByVal acTrans As Transaction) As String
        Dim btr As BlockTableRecord
        btr = acTrans.GetObject(blkref.DynamicBlockTableRecord, OpenMode.ForRead)
        Return btr.Name
    End Function
 Gaston Nunez
Message 5 of 15
in reply to: hgasty1001
Think you can help me with this Gaston?
It's related to this topic.
http://forums.autodesk.com/t5/NET/Dynamic-Block-Programatic-creation/td-p/4715109
Message 6 of 15
hgasty1001
I think you should take a look to the developer documentation, this link will help you to understand the object hierarchy in AutoCAD: Hierarchy
May be I'm wrong, but I think you can't create create a dynamic block definition with .NET API. Another thing is a block reference, and there is no problem creating one and driving its parameters with the .NET API.
Gaston Nunez
Message 7 of 15
swaywood
hi i have tried, but allway get the "*uxxx" name.
my block is not a dynamic block
Message 8 of 15
_gile
If you could attach a little dwg file with one or more of these anonymous blocks.
Gilles Chanteau
GileCAD
GitHub
Message 9 of 15
swaywood
i attached the dwg file
the block name contains "ISO A1"
and the block description contains "ISO A1" too
i just want to get the blockreforence which contains 'ISO A1" , by block name or by block descrption.
Message 10 of 15
_gile
I don't know how it is possible to get this kind of non-dynamic anonymous block table record...
Anyway, you can get the block table record description using the BlockTableRecord.Comments property.
Gilles Chanteau
GileCAD
GitHub
Message 11 of 15
swaywood
in reply to: _gile
could you tell me how to get the block description?
Message 12 of 15
swaywood
in reply to: _gile
hi,gile
thank you, i have get the block description by blocktablerecord.comments.
Message 13 of 15
swaywood
in reply to: _gile
hi,gile
I solved my problem,thank you.
but how can you know the 'comments' property is the same with block description, is there any dictionary descripe this?
i want to know the skill, then i can solve some other problem by myself.
Message 14 of 15
_gile
I use the ObjectARX docs (here) and/or the Visual Studio Object Browser.
Gilles Chanteau
GileCAD
GitHub
Message 15 of 15
swaywood
in reply to: _gile
hi,gile,I found the 'comments' property in the arxdocs, thanks again!
”Boost
