.NET
How to get the faces of Solid3d?
2 REPLIES 2
tomans
752 Views, 2 Replies
Hi,there.
Now I have gotten a Solid3d object , and I want to access the faces of this Solid3d object .
So , is there any way or code example to achieve it?
Thank you very much.
Tags (2)
2 REPLIES 2
Alexander.Rivilis
in reply to: tomans
http://through-the-interface.typepad.com/through_the_interface/2008/09/traversing-a-3d.html
Facebook | Twitter | LinkedIn
Expert Elite Member
tomans
in reply to: Alexander.Rivilis
Thank you very much , and this is helpful for me.
”Boost
