.NET
How to get the Drawing Modified date
6 REPLIES 6
746 Views, 6 Replies
Hi
I am looking to get the active document modified date that is displayed when you right click on the file, hit properties and go to the Statistics tab.
I appreciate any help
Raul
6 REPLIES 6
You'd save time using google for stuff like this...
DateTime lastWrite = System.IO.File.GetLastWriteTime(@"c:\test.txt");
wrote in message news:5479424@discussion.autodesk.com...
Hi
Raul
In addition to using the file system as Paul suggests,
you can also use the Tdupdate property of the Database.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
Hi
Raul
Duh... I should have realized there was a built in property. Thanks Tony!
Was my 'dxfin' method in line? Only thing I saw in the object browser..
"Tony Tanzillo" wrote in message
news:5482741@discussion.autodesk.com...
Hi
Raul
Hi Paul. DxfIn() is the only way I'm aware of.
"Paul Richardson" wrote in message news:5482795@discussion.autodesk.com...
Hi
Raul
Cheers!
news:5482879@discussion.autodesk.com...
Hi
Raul
Thanks guys for your help
Raul
”Boost
