.NET
.NET
Member
luvina_lyducdu
Message 1 of 7 (406 Views)
How to get rid of the message after exporting layout
406 Views, 6 Replies
10-06-2013 07:50 PM
Hi everyone.
I want to export all layouts in a DWG file automatically with this kind of code:
LayoutManager.Current.CurrentLayout = "Layout1"
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("EXPORTLAYOUT " & strFilePath, True, False, False)
The layout is exported well, but each time a layout has been exported, a message appears with a question: "The file was successfully created. Do you want to open it now?", and the next layout won't be exported until user click button "Open" or "Don't open". I want export all layouts automatically without user input, so I don't want the message displays after exporting. How can I get rid of the dialog?
Thank you for any suggestion.
if you send a LISP-string to the SendCommand, the question is not asked.
(command "_EXPORTLAYOUT")
- alfred -
no, instead of sending "_EXPORTLAYOUT" you should send "(command ""_EXPORTLAYOUT"")", it does not matter if you send it via COM or like shown in OP.
- alfred -
Hi Alfred
Thank you for your advice. I tried that way and it was OK.
I have an another little problem.
When the command EXPORTLAYOUT is executed, the AutoCAD window appears, despite the fact that I forced it to hide by this statement: Application.MainWindow.Visible = False. I want the program works silently so don't want it to show to users. How can I make it?
Alfred.NESWADBA
Message 2 of 7 (401 Views)
Re: How to get rid of the message after exporting layout
10-06-2013 08:15 PM in reply to: luvina_lyducdu
- alfred -
Alfred NESWADBA
Member
luvina_lyducdu
Message 3 of 7 (397 Views)
10-06-2013 08:51 PM in reply to: Alfred.NESWADBA
Hi Alfred
Do you mean SendCommand from the COM document object, like this:
Dim app As AcadApplication = Application.AcadApplication
app.ActiveDocument.SendCommand("_EXPORTLAYOUT")
I tried but the result is the same, the message still appear
Alfred.NESWADBA
Message 4 of 7 (387 Views)
10-06-2013 09:52 PM in reply to: luvina_lyducdu
- alfred -
Alfred NESWADBA
Member
luvina_lyducdu
Message 5 of 7 (340 Views)
10-07-2013 07:10 PM in reply to: luvina_lyducdu
Hi Alfred
Alfred.NESWADBA
Message 6 of 7 (329 Views)
10-07-2013 11:24 PM in reply to: luvina_lyducdu
sorry, I know it happens sometimes, but I haven't tried to avoid that.
I would first look for events reacting to window status changes.
If that does not work, maybe it's a help to not minimize the application window to taskbar, instead let the application window stay on desktop, but make it as small as possible :smileywink:
HTH, - alfred -
PS: another problem should be placed as new thread so anyone searching that issue can find it!
Alfred NESWADBA
SENL1362
Message 7 of 7 (202 Views)
12-07-2013 04:24 PM in reply to: Alfred.NESWADBA
Bit  late but for not too large drawings this export a layout in the background with acceptable performance
        [CommandMethod("EL")]
        public void ExportLayout()
            Document dwg = Application.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            string dwgSourcePathname = @"C:\temp\test.dwg";
            string dwgDestPatname = Regex.Replace(dwgSourcePathname, ".dwg", "_2.dwg");
            string layoutNameToExport = "ThatsTheOne";
            try
                ExportLayout(dwgSourcePathname, dwgDestPatname, layoutNameToExport);
                ed.WriteMessage("\n{0} saved in {1}", layoutNameToExport, dwgDestPatname);
            catch (System.Exception ex)
                ed.WriteMessage("\n{0}", ex.Message);
        public void ExportLayout(string dwgSourcePathname,string dwgDestPathname,string layoutNameToExport)
            using (Database db = new Database(false, true))
                db.ReadDwgFile(dwgSourcePathname, FileShare.ReadWrite, false, null);
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    DBDictionary layoutDICT = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForWrite);
                    foreach (DBDictionaryEntry dictEntry in layoutDICT)
                        Layout layout = (Layout)tr.GetObject(dictEntry.Value, OpenMode.ForRead);
                        if (!layout.ModelType && !Regex.IsMatch(layout.LayoutName, layoutNameToExport, RegexOptions.IgnoreCase))
                            layout.UpgradeOpen();
                            layout.Erase();
                    string tmpPathname = Path.GetTempFileName();
                    db.SaveAs(tmpPathname, DwgVersion.Current);
                    if (!File.Exists(dwgDestPathname))
                        File.Move(tmpPathname, dwgDestPathname);
                    else
                        try
                            File.Copy(tmpPathname,dwgDestPathname,true);
                        catch
                            throw new System.Exception(string.Format("Error: Failed to overwrite: {0}, {1} saved in {2}",dwgDestPathname,layoutNameToExport,tmpPathname));
                    tr.Commit();
