.NET
How to get offset polyline points coordinates?
1 REPLY 1
446 Views, 1 Reply
I tried to offset an existing polyline and get the points coordinates of the
result but failed
Dim outer As Autodesk.AutoCAD.Interop.Common.AcadLWPolyline' existing
polyline
Dim inner As Object ' result
Dim OuterPoints As Object ' array of existing points coordinates
Dim InnerPoints As Object ' array of result points coordinates
inner = outer.Offset(20)
OuterPoints = outer.Coordinates()' it's alright
InnerPoints= ?????
1 REPLY 1
How does the failure manifest itself? Do you get an exception? Do you get
other unexpected results?
Albert
"technosterone" wrote in message
news:4898867@discussion.autodesk.com...
result but failed
polyline
InnerPoints= ?????
”Boost
