.NET
How to get collection object after explod a block
5 REPLIES 5
778 Views, 5 Replies
Hi All,
I would like explode a block which still maintain all sub blocks' XData
myBlockRef.ExplodeToOwnerSpace()
 The above code does the job. However I can not get the exploded collection
Use the following code I can get object collection but there is no XData for each sub block.
Dim colAssemblyEnt As DBObjectCollection = New DBObjectCollection()
 myBlockRef.Explode(colAssemblyEnt)
My question is how can I get the sub block collection with each block's XData?
5 REPLIES 5
the exploded block also lost the child group
hgasty1001
in reply to: hgasty1001
Thanks for your reply.
The block doesn't solve my problem.
Virupaksha_aithal
check this blog post http://adndevblog.typepad.com/autocad/2012/05/getting-the-entities-created-from-explodetoownerspace-... . Though the blog is in C#, logic should help.
thanks
Virupaksha Aithak
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
in reply to: Virupaksha_aithal
”Boost
