Ok! I do it (minimum testing). Now flicking with LineWeight changes work also with BlockReference:
=========Beginning of the citation==============
using System ;
using System.Collections ;
using System.Threading;
using Autodesk.AutoCAD.Runtime ;
using Autodesk.AutoCAD.Geometry ;
using Autodesk.AutoCAD.ApplicationServices ;
using Autodesk.AutoCAD.EditorInput ;
using Autodesk.AutoCAD.DatabaseServices ;
using Autodesk.AutoCAD.Interop ;
using Autodesk.AutoCAD.Interop.Common;
[assembly: CommandClass(typeof(ZoomLibrary.Zoom))]
namespace ZoomLibrary
public class Zoom
// Function for zooming entity on screen
static public void ZoomObject(ObjectId id, double zoomFactor)
Database db = HostApplicationServices.WorkingDatabase;
AcadApplication app = (AcadApplication) Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
Point3d center;
double zoomHeight = 0.0;
using (Transaction tr = db.TransactionManager.StartTransaction())
object oMinpt = new object(), oMaxpt = new object();
double [] dMinpt = new double[3], dMaxpt = new double[3];
Entity en = (Entity) tr.GetObject(id,OpenMode.ForRead);
AcadEntity en_com = en.AcadObject as AcadEntity;
object minPt = new object(), maxPt = new object();
en_com.GetBoundingBox(out oMinpt, out oMaxpt);
dMinpt = (double []) oMinpt; dMaxpt = (double []) oMaxpt;
double heightEnt = dMaxpt[1] - dMinpt[1];
double widthEnt = dMaxpt[0] - dMinpt[0];
object objRes = app.ActiveDocument.GetVariable("SCREENSIZE");
Point2d screenRes = new Point2d((double []) objRes);
double aspectScreen = screenRes.Y / screenRes.X;
double aspectEnt = heightEnt / widthEnt;
if (aspectEnt < aspectScreen) zoomFactor *= (aspectEnt / aspectScreen);
center = new Point3d(
(dMinpt[0]+dMaxpt[0]) * 0.5,
(dMinpt[1]+dMaxpt[1]) * 0.5,
(dMinpt[2]+dMaxpt[2]) * 0.5
zoomHeight = heightEnt*100/Math.Max(zoomFactor,1e-6);
app.ZoomCenter(center.ToArray(),zoomHeight);
static public DBObjectCollection DeepCloneExplode(Entity en)
DBObjectCollection fullCol = new DBObjectCollection();
BlockReference blkRef = en as BlockReference;
if (blkRef != null) {
DBObjectCollection partCol = new DBObjectCollection();
AttributeCollection attCol = blkRef.AttributeCollection;
Document doc = Application.DocumentManager.MdiActiveDocument;
using (DocumentLock doclock = doc.LockDocument()) {
using (Transaction tr = doc.TransactionManager.StartTransaction()) {
foreach (ObjectId id in (IEnumerable) attCol) {
AttributeReference attRef = (AttributeReference) tr.GetObject(id,OpenMode.ForRead);
if (!attRef.Invisible) {
DBText txt = new DBText();
txt.SetDatabaseDefaults(doc.Database);
txt.AdjustAlignment(doc.Database);
txt.VerticalMode = attRef.VerticalMode;
txt.HorizontalMode = attRef.HorizontalMode;
txt.Position = attRef.Position;
txt.Normal = attRef.Normal;
txt.Rotation = attRef.Rotation;
txt.Height = attRef.Height;
txt.WidthFactor = attRef.WidthFactor;
txt.Thickness = attRef.Thickness;
txt.TextStyle = attRef.TextStyle;
txt.TextString = attRef.TextString;
txt.Oblique = attRef.Oblique;
txt.Color = attRef.Color;
txt.LayerId = attRef.LayerId;
txt.AlignmentPoint = attRef.AlignmentPoint;
fullCol.Add(txt);
en.Explode(partCol);
foreach (DBObject en_col in partCol) {
AttributeDefinition attdef = en_col as AttributeDefinition;
if (attdef == null) {
using (DBObjectCollection locCol = DeepCloneExplode((Entity) en_col)) {
foreach (DBObject en_col1 in locCol) fullCol.Add(en_col1);
partCol.Dispose();
} else {
fullCol.Add((en.ObjectId != ObjectId.Null)?(DBObject)en.Clone():(DBObject)en);
return fullCol;
// Flicking object with help of LineWeight changes
static public void FlickObjectLineWeight(ObjectId id, int num, int delay1, int delay2)
object lwdisplay = Application.GetSystemVariable("LWDISPLAY");
if ((short)lwdisplay == 0) Application.SetSystemVariable("LWDISPLAY",(short)1);
LineWeight prevLineWeight = LineWeight.ByLineWeightDefault;
DBObjectCollection expEnts = null;
ArrayList ids = new ArrayList();
// Cloneing entities for highlighting
expEnts = DeepCloneExplode(en);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(en.OwnerId, OpenMode.ForWrite);
foreach (Entity ent in expEnts) {
ObjectId expid = btr.AppendEntity(ent);
ids.Add(expid);
tr.AddNewlyCreatedDBObject(ent,true);
expEnts.Dispose();
tr.Commit();
for (int i = 0; i < num; i++)
// Highlight entity
foreach (ObjectId eId in ids) {
Entity en = (Entity) tr.GetObject(eId,OpenMode.ForWrite);
en.LineWeight = LineWeight.LineWeight211; // Maximum lineweight
tr.Commit();
doc.Editor.UpdateScreen();
// Wait for delay1 msecs
Thread.Sleep(delay1);
// Unhighlight entity
en.LineWeight = prevLineWeight;
tr.Commit();
// Wait for delay2 msecs
Thread.Sleep(delay2);
// Erase cloned entities
en.Erase();
tr.Commit();
Application.SetSystemVariable("LWDISPLAY",lwdisplay);
// Flicking object with Highlight
static public void FlickObjectHighlight(ObjectId id, int num, int delay1, int delay2)
// Highlight entity
Entity en = (Entity) tr.GetObject(id,OpenMode.ForWrite);
ObjectId[] ids = new ObjectId[1] ; ids[0] = id;
SubentityId index = new SubentityId(SubentityType.Null, 0);
FullSubentityPath path = new FullSubentityPath(ids, index);
en.Highlight(path,true);
tr.Commit();
en.Unhighlight(path,true);
tr.Commit();
static public void FlickObjectVisible(ObjectId id, int num, int delay1, int delay2)
bool prevVisibility = true;
for (int i = 0; i < num; i++) {
// Highlight entity
prevVisibility = en.Visible;
en.Visible = !en.Visible;
tr.Commit();
en.Visible = prevVisibility;
tr.Commit();
// Define Command "TestZoom"
[CommandMethod("TestZoom")]
static public void TestZoom() {
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
PromptEntityResult rse = ed.GetEntity("\nSelect Entity: ");
if (rse.Status == PromptStatus.OK) {
double zoomFactor = 100.0;
PromptDoubleOptions pdo = new PromptDoubleOptions("\nEnter zoom factor in percent (0...100) <100>: ");
pdo.UseDefaultValue = true; pdo.DefaultValue = zoomFactor;
pdo.AllowNegative = false; pdo.AllowZero = false; pdo.AllowNone = false;
PromptDoubleResult rsd = ed.GetDouble(pdo);
switch (rsd.Status) {
case PromptStatus.Cancel:
case PromptStatus.Error:
return;
case PromptStatus.OK:
zoomFactor = rsd.Value;
break;
default:
break;
ZoomObject(rse.ObjectId,zoomFactor);
FlickObjectLineWeight(rse.ObjectId,3,350,200);
=========The end of the citation================
I think it is enough!
