.NET
How to get Block's Layer name?
30 REPLIES 30
Message 1 of 31
MGOMKD
2004 Views, 30 Replies
After searching for a long time on the web, does anyone know how to get the block's layer name?
I iterate through Blocks to get informations but i'm not able to code the source to obtain what i want?
Sample source taken from AutoCAD.NET site:
 Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            '' Open the Block table for read
            Dim acBlkTbl As BlockTable = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
            '' Open the Block table record Model space for read
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForRead)
            '' Step through the Block table record
            For Each acObjId As ObjectId In acBlkTblRec
                acDoc.Editor.WriteMessage(vbLf & "DXF name: " & acObjId.ObjectClass().DxfName)
                acDoc.Editor.WriteMessage(vbLf & "ObjectID: " & acObjId.ToString())
                acDoc.Editor.WriteMessage(vbLf & "Handle: " & acObjId.Handle.ToString())
                acDoc.Editor.WriteMessage(vbLf)
            Next
            '' Dispose of the transaction
        End Using
 Maybe use nested transaction to iterate through LayerTableId?
ideas?
30 REPLIES 30
Message 21 of 31
Hallex
in reply to: MGOMKD
Shortly, the Minpoint is means a lower left corner of bounding box of the object,
Maxpoint is opposite corner, kind of 2 corners of text frame
Here is a code to demonstate the mtext frame
    <CommandMethod("FMM")> _
    Public Shared Sub TextFrame()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim db As Database = doc.Database
        Using docloc As DocumentLock = doc.LockDocument()
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Try
                    Dim peo As PromptEntityOptions = New PromptEntityOptions(vbCr & "select mtext")
                    peo.SetRejectMessage(vbCr & "selected object is not mtext")
                    peo.AddAllowedClass(GetType(MText), True)
                    Dim id As ObjectId = ed.GetEntity(peo).ObjectId
                    Using mtext As MText = CType(tr.GetObject(id, OpenMode.ForWrite), MText)
                        If mtext Is Nothing Then
                            Return
                        Using newtxt As MText = mtext.Clone()
                            newtxt.Rotation = 0
                            newtxt.Width = mtext.ActualWidth
                            newtxt.Height = mtext.ActualHeight
                            Dim off As Double = newtxt.TextHeight * 0.35
                            Dim ext As Extents3d = newtxt.GeometricExtents
                            Dim p1 As Point2d = New Point2d(ext.MinPoint.X - off, ext.MinPoint.Y - off)
                            Dim p3 As Point2d = New Point2d(ext.MaxPoint.X + off, ext.MaxPoint.Y + off)
                            Dim p2 As Point2d = New Point2d(p3.X, p1.Y)
                            Dim p4 As Point2d = New Point2d(p1.X, p3.Y)
                            Dim pline As New Polyline(4)
                            pline.AddVertexAt(0, p1, 0, 0, 0)
                            pline.AddVertexAt(1, p2, 0, 0, 0)
                            pline.AddVertexAt(2, p3, 0, 0, 0)
                            pline.AddVertexAt(3, p4, 0, 0, 0)
                            pline.Closed = True
                            pline.ColorIndex = 1
                            pline.ConstantWidth = newtxt.TextHeight * 0.13
                            pline.TransformBy(Matrix3d.Rotation(mtext.Rotation, ed.CurrentUserCoordinateSystem.CoordinateSystem3d.Zaxis, mtext.Location))
                            Dim bt As BlockTable = CType(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                            Dim btr As BlockTableRecord = CType(tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
                            btr.AppendEntity(pline)
                            tr.AddNewlyCreatedDBObject(pline, True)
                        End Using
                    End Using
                    tr.Commit()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    ed.WriteMessage(vbCr & ex.Message & vbCr & ex.StackTrace)
                End Try
            End Using
        End Using
    End Sub
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 22 of 31
Hallex
in reply to: Hallex
Here is example how to create the mtext (I'm using syntax fo A2010)
 <CommandMethod("mtx")> _
    Public Sub createMtext()
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        Using tr
            Dim strvalue As String = "first text line\Psecond text line\Pthird text line"
            Dim pt As Point3d = New Point3d(10, 20, 0)
            Dim mtx As New MText
            mtx.Location = pt
            mtx.SetDatabaseDefaults()
            mtx.TextStyleId = db.Textstyle
            mtx.TextHeight = db.Dimtxt
            mtx.Width = 0
            mtx.Contents = strvalue
            mtx.Attachment = AttachmentPoint.BottomCenter
            mtx.SetAttachmentMovingLocation(mtx.Attachment)
            Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
            btr.AppendEntity(mtx)
            tr.AddNewlyCreatedDBObject(mtx, True)
            mtx.Width = mtx.ActualWidth
            tr.Commit()
        End Using
    End Sub
~'J'~
Message 23 of 31
MGOMKD
in reply to: Hallex
Hi Hallex,
I worked on your source code about stocking Polylines coordinates.
'Insertion du texte'
                                    Dim MyVertices as Point3d
Dim Coord as Long
Dim X as Double
Dim Y as Double
Dim Z as Double
For Coord = 0 To MyPolyLine.NumberOfVertices - 1 MyVertices = MyPolyLine.GetPoint3dAt(Coord) X = X + MyVertices.Coordinate(0) Y = Y + MyVertices.Coordinate(1) Z = Z + MyVertices.Coordinate(2) Next X = X / MyPolyLine.NumberOfVertices Y = Y / MyPolyLine.NumberOfVertices Z = Z / MyPolyLine.NumberOfVertices
 I use your function to obtain average X, Y and Z to insert MText in the middle of the piece!
Do you know how to obtain NumberOfVertices of "Region"?
You drive me on the right way! Thank you Hallex.
Message 24 of 31
Hallex
in reply to: MGOMKD
You have to calculate middle point using GetPoint3dAt method,
like this:
Dim cp as point3d= pline.GetPoint3dAt((pline.endparam-plne.startparam)/ 2)
then change mtext attachment like this:
mtx.location=cp
mtx.Attachment = AttachmentPoint.MiddleCenter etc...
~'J'~
Message 25 of 31
MGOMKD
in reply to: Hallex
Great source code Hallex, but GetPoint3d method doesn't appear with "Region".
I found a another way to get midpoint by using "Centroid", i used it when i wrote source code in VBA.
'Déclaration variable'
Dim MyRegion As AcadRegion = TryCast(MyEnt, Entity)
acMText = New MText() X = MyRegion.Centroid(0) Y = MyRegion.Centroid(1) Z = MyRegion.Centroid(2)
With acMText acMText.SetDatabaseDefaults() acMText.Location = New Point3d(X, Y, Z) acMText.Attachment = AttachmentPoint.MiddleCenter acMText.TextHeight = acHeightText acMText.Contents = i End With
acBlkTblRec.AppendEntity(acMText) acTrans.AddNewlyCreatedDBObject(acMText, True)
 Centroid only works with "Region".
Message 26 of 31
Hallex
in reply to: MGOMKD
Sorry I've  thought you told me about Polyline coordinates,
Glad you got it to work by yourself
Cheers 🙂
~'J'~
Message 27 of 31
MGOMKD
in reply to: Hallex
Your help is always welcome, and I understant more and more the structure of AutoCAD.
Thanks a lot.
Message 28 of 31
Hallex
in reply to: MGOMKD
I used same way but a bit different one, see if thisis  working for you
    ''  Imports System.Reflection
    ''  Imports Autodesk.AutoCAD.Interop.Common
    ''------------------------------------    WH    ------------------------------''
    <CommandMethod("LabelArea", "lar", CommandFlags.UsePickSet Or CommandFlags.Redraw)> _
    Public Shared Sub CreateRegionFromPline()
        Try
                Dim btr As BlockTableRecord = TryCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                Dim peo As PromptEntityOptions = New PromptEntityOptions(vbLf + "Select Polyline: ")
                peo.SetRejectMessage(vbLf + "You have to select closed Polyline!")
                peo.AddAllowedClass(GetType(Polyline), False)
                Dim res As PromptEntityResult = ed.GetEntity(peo)
                If res.Status <> PromptStatus.OK Then Return
                Dim ent As Entity = DirectCast(tr.GetObject(res.ObjectId, OpenMode.ForRead), Entity)
                Dim pline As Polyline = TryCast(ent, Polyline)
                If Not pline.Closed Then Return
                Dim copy As Polyline = pline.Clone
                If Not copy.IsWriteEnabled Then copy.UpgradeOpen()
                btr.AppendEntity(copy)
                tr.AddNewlyCreatedDBObject(copy, True)
                Dim dbcoll As New DBObjectCollection()
                dbcoll.Add(copy)
                Dim regColl As New DBObjectCollection()
                regColl = Region.CreateFromCurves(dbcoll)
                Dim reg As Region = DirectCast(regColl(0), Region)
                btr.AppendEntity(reg)
                tr.AddNewlyCreatedDBObject(reg, True)
                tr.TransactionManager.QueueForGraphicsFlush()
                Dim obj As Object = reg.AcadObject
                Dim dbl() As Double = TryCast(obj.GetType().InvokeMember("Centroid", BindingFlags.GetProperty, Nothing, obj, Nothing), Double())
                Dim cp As Point3d = New Point3d(dbl(0), dbl(1), pline.Elevation)
                ed.WriteMessage(vbLf + "{0}" + "{1}", cp.X, cp.Y)
                mtx.Location = cp
                mtx.Width = 0
                mtx.Contents = String.Format("{0:f3}", pline.Area)
                If copy IsNot Nothing Then
                    copy.Erase()
                If reg IsNot Nothing Then
                    reg.Erase()
                tr.Commit()
            End Using
            ed.WriteMessage((vbLf + ex.Message & vbLf) + ex.StackTrace)
        Finally
        End Try
    End Sub
~'J'~
Message 29 of 31
MGOMKD
in reply to: Hallex
Hi Hallex,
Thank you for your code, I really have to work on it! Not quietly but surely!
Another way to obtain Region.Centroid.
Dim MyRegion As AcadRegion = MyEnt.AcadObject
Z = 0
With acMText
End With
 Coding is so fascinating!
Message 30 of 31
Hallex
in reply to: MGOMKD
So, the issue is solved?
~'J'~
Message 31 of 31
MGOMKD
in reply to: Hallex
Hi Hallex,
My source code is progressing!, I'll give it to you soon, but I have to chase every encounter bugs.
See you.
”Boost
