.NET
Active Contributor
MGOMKD
Message 11 of 31 (265 Views)
Re: How to get Block's Layer name?
07-30-2012 05:56 AM in reply to: Hallex
Hi Hallex,
I'm very surprised you're very quick! Thank you.
Now i have to understand code and work on it.
See you!
Hallex
Message 12 of 31 (263 Views)
07-30-2012 06:55 AM in reply to: MGOMKD
Good to hear that,
Just a hint, you could be able to collect all of values of the particular subentity
into the
 List(Of (List (Of String))
( every single item inside into the List (of String)),
then this would be easier to write to the data file on another storage,
hth,
~'J'~
Active Contributor
MGOMKD
Message 13 of 31 (238 Views)
08-08-2012 01:01 AM in reply to: Hallex
Hi Hallex, how are you?
I try de write the best code to obtain what i want but when i run it on AutoCAD, i have a dialog box error.
So in a module vars.
Module Paramètres
    '* Paramètres du Document Actif *'
    Public acDocs As DocumentCollection = Application.DocumentManager
    Public acDoc As Document = acDocs.MdiActiveDocument
    Public acCurDb As Database = acDoc.Database
    Public acTrans As Transaction
Public acBlkTbl As BlockTable
    Public acBlkTblRec As BlockTableRecord
End Module
 And the code
Sub ExcelApp(ByVal LayerVal)
        '* Génération du fichier Excel *'
Using acTrans = acCurDb.TransactionManager.StartTransaction() acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForRead)
For Each acObjId As ObjectId In acBlkTblRec Dim MyEnt As Entity = acTrans.GetObject(acObjId, OpenMode.ForRead) If MyEnt.Layer = LayerVal Then Select Case acObjId.ObjectClass.DxfName '******' '* ARC *' '******' Case Is = "ARC" Dim MyArc As AcadArc = CType(acTrans.GetObject(MyEnt.AcadObject, OpenMode.ForRead), AcadArc) MsgBox(MyArc.ArcLength) End If Next acObjId
End Using
 Error message: Impossible to cast type's object.
                          'Autodesk.AutoCAD.DatabaseServices.Arc' to 'Autodesk.AutoCAD.Interop.Common.AcadArc'
Am i on the right way?
Active Contributor
MGOMKD
Message 14 of 31 (206 Views)
08-09-2012 01:46 AM in reply to: MGOMKD
Hi all,
I just found what's wrong in my source code!
Change these lines:
 by:
Dim MyArc As Autodesk.AutoCAD.DatabaseServices.Arc = TryCast(MyEnt, Entity)
MsgBox (MyArc.Length)
 Thanks to Hallex!
Hallex
Message 15 of 31 (203 Views)
08-09-2012 02:07 AM in reply to: MGOMKD
Glad you solved it by yourself,
Happy coding :smileyhappy:
~'J'~
Active Contributor
MGOMKD
Message 16 of 31 (176 Views)
08-17-2012 07:38 AM in reply to: Hallex
I've met another matter!
When I iterate through specifics entities (like LWPOLYLINE, LINE, CIRCLE,...etc) sometimes my source code deal with "POINT". So I would like to cast it to obtain coordinates (X, Y, Z).
Dim MyPoint As Point3d = TryCast(MyEnt, Entity)
But the matter is I cannot access coordinate of these entity, cause Point3d belongs to Autodesk.AutoCAD.Geometry whereas MyEnt belong to AutoDesk.AutoCAD.DatabaseServices
How could I reach these informations?
Hallex
Message 17 of 31 (169 Views)
08-17-2012 07:59 AM in reply to: MGOMKD
You could be able to get coordinates from polyline
with help of these functions:
''============================= LWPolyline =======================
 Public Shared Function getAllVertices(ByVal ent As Polyline) As Point2dCollection
    Dim verCollection As Point2dCollection = New Point2dCollection()
    Dim vertex As Point2d
    Dim i As Integer = 0
      For i = 0 To ent.NumberOfVertices - 1
        vertex = ent.GetPoint2dAt(i)
     verCollection.Add(vertex)
    Next
    Return verCollection
  End Function
''============================= 3dPoly =======================
     Public Shared Function Get3dPolyVertices(ByVal poly3d As Polyline3d) As Point3dCollection
            Dim pts As New Point3dCollection
            For i As Integer = 0 To poly3d.EndParam
                pts.Add(poly3d.GetPointAtParameter(i))
            Next i
        Return pts
    End Function
 From line you can get coordinates:
Dim sp as point3d= line.StartPoint
dim ep as point3d= line.EndPoint
same way for arc,circle etc
just find in Intellisence box appropriate properties for them all
~'J'~
Active Contributor
MGOMKD
Message 18 of 31 (165 Views)
08-17-2012 08:21 AM in reply to: Hallex
Hi Hallex!
Always at the top!
I work on it, thanks a lot.
Hallex
Message 19 of 31 (149 Views)
08-17-2012 09:40 PM in reply to: MGOMKD
:Glad to help
Cheers :smileyhappy
~'J'~
Active Contributor
MGOMKD
Message 20 of 31 (141 Views)
08-18-2012 06:33 AM in reply to: Hallex
Hi Hallex,
I had found another way to obtain coords.
Case Is = "POINT"
                                    '* POINT *'
                                    'Insertion du texte'
                                    acMText = New MText()
                                    Dim X as Double = MyEnt.GeometricExtents.MinPoint.X
                                    Dim Y as Double = MyEnt.GeometricExtents.MinPoint.Y
                                    Dim Z as Double = MyEnt.GeometricExtents.MinPoint.Z
                                    With acMText
                                        acMText.SetDatabaseDefaults()
                                        acMText.Location = New Point3d(X, Y, Z)
                                        acMText.Attachment = AttachmentPoint.BottomLeft
                                        acMText.TextHeight = acHeightText
                                        acMText.Contents = i
                                    End With
                                    acBlkTblRec.AppendEntity(acMText)
                                    acTrans.AddNewlyCreatedDBObject(acMText, True)
                                    'Libération de la variable'
                                    MyEnt = Nothing
                                    acMText = Nothing
 But what the difference between "MinPoint" and "MaxPoint"? I tried twice and it gaves the same result!
Thank You.
